Broke piston #2695935
09/09/19 08:37 PM
09/09/19 08:37 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Broke a thin piece off this piston. Not sure what its for. Can it still be used?
Re: Broke piston [Re: johnfin] #2695940
09/09/19 08:53 PM
09/09/19 08:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
not usable for me.
Re: Broke piston [Re: stumpy] #2695979
09/09/19 10:38 PM
09/09/19 10:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Nope. Teardown time, in my opinion.
I'd sure want to know the why & how, and who the piston manufacturer is.
I'd think there's debris everywhere, as well.
Re: Broke piston [Re: topside] #2695984
09/09/19 10:59 PM
09/09/19 10:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Piston skirts can be broken while out of the engine by letting the rod flop onto it to hard. Been there done that lesson learned. blush
Re: Broke piston [Re: stumpy] #2696111
09/10/19 12:00 PM
09/10/19 12:00 PM
central il.
second 70 Offline
second 70  Offline
central il.
I did worse than that. I was changing the wax ring on a toilet and when I had it off cleaning the base the oak seat feel open and smashed the tank. So off to the store to spend $200 for the original $.99 repair. Lol
Re: Broke piston [Re: second 70] #2696291
09/10/19 07:29 PM
09/10/19 07:29 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Its not the skirt, its above the wrist pin. I hit it with a piece of wood trying to get the stuck piston out.
Re: Broke piston [Re: johnfin] #2696311
09/10/19 09:14 PM
09/10/19 09:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Junk.
Re: Broke piston [Re: stumpy] #2696323
09/10/19 09:45 PM
09/10/19 09:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Trying to save pistons in a stuck motor is a waste of time. Save the block and the crank, get new pistons to fit the over bore the motor will need anyway. Gene
Re: Broke piston [Re: poorboy] #2696358
09/10/19 11:21 PM
09/10/19 11:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree
Once the steel rings weld themselves into the cast iron cylinder walls you will need to have it bored out to get rid of those stuck parts damage to the cylinder walls from the rings to the cylinder walls shruggy scope
