22" radiator 38086 #2695797
09/09/19 01:50 PM
09/09/19 01:50 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
I'm trying to research to see what applications this radiator will fit. Its a 22" for an auto. The only #'s on it are the 38086. The hose config is upper on the pass side and the lower is on the drivers side. It came out of my 67 383 Belvedere and curious to see what else it may have been used in.
Re: 22" radiator 38086 [Re: Belvedere1] #2695849
09/09/19 04:42 PM
09/09/19 04:42 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
part numbers are 7-digits
vendor codes are 5-digits
the 7-digit part # is sometimes on a tag, soldered to the upper tank, sounds like it is missing
the only 22" 1967 b-body big block radiator listed in GG's "white book" is 2785960 = 22" 383 2bbl
you could research the above number and compare to your radiator or post pics & someone may have an idea what its original use was shruggy
Re: 22" radiator 38086 [Re: 6bblgt] #2695962
09/09/19 09:59 PM
09/09/19 09:59 PM
Phoenix, AZ
Phoenix, AZ
Yes tag is long gone and who knows if it was actually original to the car.
Re: 22" radiator 38086 [Re: 6bblgt] #2696015
09/10/19 01:10 AM
09/10/19 01:10 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
You have a pic of the rad?
Abe Lincoln
