A trip to Milan dragway for some TNT
#2695425
09/08/19 11:42 AM
09/08/19 11:42 AM
Posts: 8,041 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Another learning curve for sure. Tried a few things to find what it likes and dislikes. I first added more pump gas to the tank diluting out the 2 gallons on 110 I added last weekend at MidMichiganMotorPlex, installed new champion race plugs c63cx(7 heat range) and removed my electric fans and replace with a 17" aluminum flex fan. Off the trailer was the best pass with a 10.666@127.30 vs the best pass last weekend of 10.401@129.75. 2nd pass I had the air bell removed just to see if it would again hurt it with nothing on top on the carb and it did. 10.669@126.19, 1mph loss. 3rd pass I switched the HS air bleed from 28 to a 30 to see if it would help on the bottom and it did not, in fact it leaned it out way too much on the top with 13.9afr thru traps and ran 10.715@126.05. 4th and last pass, put the 28's back in, put the air bell back on and removed the 1" wilsons tapered spacer. It ran a 10.711@126.47 with much cooler air. It should of picked up more than that IMO, so the looks like the spacer stays on. I should have put a bigger jet in the rear, maybe 2 sizes, because it was running 13+afr's every pass. I think the flex fan cost about a 10th or 2 and 2 or 3mph. Timing was left at 36* on every pass. I ran 1 brand new plug 1 time down the track. I will cut it open and post a pic. Only way this cars going any quicker is with some hard parts changing, like 440-1 heads and a nice Roller. Not impressed with these Victors. Here's a pass down the track. https://youtu.be/mKG7lJhLuac
Re: A trip to Milan dragway for some TNT
[Re: mopar dave]
#2695438
09/08/19 12:33 PM
09/08/19 12:33 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Good Video, I think it could use more converter. You are still legging out 1st gear for 2000 more RPM after the flash. I am not a big block guy but that seems like a lot to me.
Why did you switch the fans? Your runs you made awhile back I think you said it ran 129MPH or so but 60d in the high 1.4s. I would look on the short end of the track for improvement.
68 Barracuda Formula S 340
[Re: mopar dave]
#2695450
09/08/19 01:06 PM
09/08/19 01:06 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Yes and I know what works best for it as is. It is a street car, so fairly happy with it anyway. Here's a pic on a single pass plug. No black specs,cool.
[Re: mopar dave]
#2695469
09/08/19 02:14 PM
09/08/19 02:14 PM
Clanton
northern,Ohio,USA
Yeah, no black specs. That run was with Dom's original tune. If you watch the AFR's in the vid it was running 13.9 thru the traps. A tad lean with the 30 HSB. I couldn't see the a/f dial clear and was looking at the color if it changed. I can read it going full screan.TY!
[Re: mopar dave]
#2695530
09/08/19 06:39 PM
09/08/19 06:39 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What motor, spec, weight ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#2695548
09/08/19 07:51 PM
09/08/19 07:51 PM
mopar dave
Mt Morris Michigan
67 Barracuda 3380# race ready 511 LD 11.25:1 MW victor heads cnc'd by hughes 330cc port flows 356@.600 .700 uses HS 1.6/1.5 rockers SFT cam spec'd by Dwayne 270/276@50-.644/.615-110 Indy 400-3 with 1" 4 hole tapered 2" mad dog headers 3.5 coll 727 w/reverse manual 8" vert 5100 stall/flash by Lenny@Ultimate Dana 4.10 28" M/T ET R radials I have read on other mopar sites guys using these victors disappointed as I unless they have 13:1 or more compression. Not many make over 700hp with the victor head.
[Re: mopar dave]
#2695591
09/08/19 09:48 PM
09/08/19 09:48 PM
Posts: 4,457 Washington
madscientist
Washington
67 Barracuda 3380# race ready 511 LD 11.25:1 MW victor heads cnc'd by hughes 330cc port flows 356@.600 .700 uses HS 1.6/1.5 rockers SFT cam spec'd by Dwayne 270/276@50-.644/.615-110 Indy 400-3 with 1" 4 hole tapered 2" mad dog headers 3.5 coll 727 w/reverse manual 8" vert 5100 stall/flash by Lenny@Ultimate Dana 4.10 28" M/T ET R radials I have read on other mopar sites guys using these victors disappointed as I unless they have 13:1 or more compression. Not many make over 700hp with the victor head. IMO, that 63 Champion is a bit cold for that CR on pump gas. You can get that in a 65. That's only 1 range hotter. Without seeing the shell it's hard to say how much hotter you should go, but I'm going to say that 63 is too cold.
[Re: mopar dave]
#2695639
09/09/19 12:34 AM
09/09/19 12:34 AM
madscientist
Washington
I'm not sure, but I was under the understanding the c63cx was the hottest in that style. Yeah, I had to look it up. The C63CX is the hottest in that style. If you can find them, you can get a C63 which is one range hotter, but it's a fine wire plug with the standard ground wire. The C65YC is the same heat range as the C63 and is one range hotter than that C63CX you are using. So the C63 and the C65YC are the same heat range, with different tip styles. BTW, the C65YC is an extended tip, which IMO is better for pump gas stuff. I used to remember this stuff off the top of my head. Tonight I had to get the book out! Sucks getting old.
[Re: moparx]
#2695731
09/09/19 10:56 AM
09/09/19 10:56 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Dave, don't take this as a dig at you or your car, but am I the only one who feels like this combo should be faster than it is?
For comparison, my 3700 lb cuda w/ a stock stroke 440, unported Indy SRs, old Team G intake w/ a 1050 dominator, mid 260s at fifty solid roller, and 14:1 compression went 10.40 at 129.1 mph. 5k stall 727 w/ 4.10s and 28" tires. The only thing my combo had better than yours is higher compression.
If there isn't something up w/ the heads, it might need a lot looser converter to get it moving? Have you had it on a dyno?
[Re: an8sec70cuda]
#2695737
09/09/19 11:14 AM
09/09/19 11:14 AM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Kinda what i thought. Figured on relatively easy 9 sec time slips
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
