Re: 2017 Dodge Ram 3500 recall
[Re: kenworth_goose]
#2692505
08/29/19 07:48 AM
08/29/19 07:48 AM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
They did that to my 18 2500 before it was sold new to me. I would jump up and down and make them put a new one on it. When you go to get an alignment you'll pay out of pocket for a new one. Pay out out of pocket for what? Not understanding
[Re: Sammy]
#2692738
08/29/19 09:47 PM
08/29/19 09:47 PM
Posts: 2,046 ky.
kenworth_goose
ky.
They did that to my 18 2500 before it was sold new to me. I would jump up and down and make them put a new one on it. When you go to get an alignment you'll pay out of pocket for a new one. Pay out out of pocket for what? Not understanding You'll pay out of pocket for arm that runs from the box to the tie rod. It will be welded and no shop is going to try and do an alignment with it welded. It's the adjusting sleeve that straightens the steering wheel after the toe is set.
[Re: Sammy]
#2695248
09/07/19 02:54 PM
09/07/19 02:54 PM
Posts: 16,128 Mesa, Arizona
dart4forte
Mesa, Arizona
Have to bring the truck back for center link bolt loose Recall. "THE FIX IS WELD THE NUT" What is this all about? Half ass fix, probably a dealers way of doing it cheaply then billing dodge for the correct fix. I would contact Dodge directly and get the correct scoop.
Abe Lincoln
[Re: dart4forte]
#2698151
09/16/19 05:36 PM
09/16/19 05:36 PM
Sammy
Wind Gap,Pa.
Have to bring the truck back for center link bolt loose Recall. "THE FIX IS WELD THE NUT" What is this all about? Half ass fix, probably a dealers way of doing it cheaply then billing dodge for the correct fix. I would contact Dodge directly and get the correct scoop. The dealers charge Dodge to do the recall so its a win/win for the dealers. More money in their pockets. Dodge Corporation losses with every recall.
[Re: dart4forte]
#2698183
09/16/19 07:06 PM
09/16/19 07:06 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
Have to bring the truck back for center link bolt loose Recall. "THE FIX IS WELD THE NUT" What is this all about? Half ass fix, probably a dealers way of doing it cheaply then billing dodge for the correct fix. I would contact Dodge directly and get the correct scoop. It really doesn't work that way. The manufacturer specifies the remedy and the NHTSA approves it. You don't want to get caught halfassing a safety recall. The liabilities could be tremendous.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2698188
09/16/19 07:19 PM
09/16/19 07:19 PM
dart4forte
Mesa, Arizona
Have to bring the truck back for center link bolt loose Recall. "THE FIX IS WELD THE NUT" What is this all about? Half ass fix, probably a dealers way of doing it cheaply then billing dodge for the correct fix. I would contact Dodge directly and get the correct scoop. It really doesn't work that way. The manufacturer specifies the remedy and the NHTSA approves it. You don't want to get caught halfassing a safety recall. The liabilities could be tremendous. There’s some pretty shady dealers out there. Last recall for suspension was on my 07. I asked one dealer what it entailed. Basicly needed the truck up on a lift to inspect the part. I ended up going to another dealer for convenience and all that happened is the service writer looked under the front of the truck and said I was good. I called Dodge and complained, they ended up sending me to the dealer I initially contacted. Turns out the tie rod was bad and they replaced it. When I complained Dodge told me they were investigating the other dealer. That dealer sold out two years later.
Abe Lincoln
