1973 400 4BBL HP Camshaft #2695103
09/07/19 02:16 AM
09/07/19 02:16 AM
3
340clone Offline OP
340clone  Offline OP
Which camshaft would be the closest replacement for a stock '73 400 HP 4BBL? What about timing set and oil pump for the same engine?
As I've been looking up these parts, there seems to be a lot of reference crossover between the base and HP 400 motor for this year. Thanks!
Re: 1973 400 4BBL HP Camshaft [Re: 340clone] #2695116
09/07/19 06:17 AM
09/07/19 06:17 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
MELLING SPD31 is supposed to be the stock HP cam for that.
Re: 1973 400 4BBL HP Camshaft [Re: 340clone] #2695280
09/07/19 05:51 PM
09/07/19 05:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The stock camshaft is the same Magnum one, the first one of the Purple camshaft series
Re: 1973 400 4BBL HP Camshaft [Re: 340clone] #2695304
09/07/19 09:03 PM
09/07/19 09:03 PM
I'd get a 3 keyway roller timing chain set & put in "advanced" & a parts house std vol oil pump will work fine for you
Re: 1973 400 4BBL HP Camshaft [Re: 340clone] #2695508
09/08/19 05:04 PM
09/08/19 05:04 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
The Summit 6400 is the same cam. I have one in my 440 and I love it.
Re: 1973 400 4BBL HP Camshaft [Re: 340clone] #2695611
09/08/19 10:40 PM
09/08/19 10:40 PM
3
340clone Offline OP
340clone  Offline OP
Thanks for all of the input. So, in an attempt to freshen up a stock engine, I originally ordered an Elgin E-327-S cam kit, Melling M-63 oil pump, and a Cloye's C-3010K timing kit. Being a '73, I didn't realize that there was a difference with it being a HP 4bbl engine. I believe the above cam is for the 2bbl version of the 400. In addition to the suggestions mentioned here, the Elgin E-1094-P also looks to be an relatively stock HP alternative according to factory specs. I am running one of those in a 440 that I have. If I return the cam and replace with one for the 4bbl, would the above pump and timing kit still work with the HP engine?
This is a good running motor and I am not looking to rebuild, but I noticed that the timing chain felt loose on inspection so I figured I'd change it and thought it wouldn't be a bad idea to change the cam, lifters and oil pump while I was in there. So this brings me to another question for the engine guys: Since it is running good, is it even worth changing the cam and oil pump out, or just change the timing chain and gears and call it good? Odometer shows a little over 100K miles. Thanks in advance!
Re: 1973 400 4BBL HP Camshaft [Re: 340clone] #2695616
09/08/19 10:49 PM
09/08/19 10:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
unless it's broke (or used up, like your timing chain set) don't "fix-it" twocents
Re: 1973 400 4BBL HP Camshaft [Re: 6bblgt] #2695707
09/09/19 10:09 AM
09/09/19 10:09 AM
moparx Offline
moparx  Offline
a saying we used at work : "if it ain't broke, keep fixin' it 'till it is !" laugh2
beer
Re: 1973 400 4BBL HP Camshaft [Re: moparx] #2695713
09/09/19 10:29 AM
09/09/19 10:29 AM
3
340clone Offline OP
340clone  Offline OP
I like the logic of the above posts!
I do think it would be a good idea to replace timing kit though, as loose as the chain is. I have not removed the cover yet, but when checking the tension of the chain via the fuel pump orifice, I can actually pull the chain into the side of the cover. That seems way too loose. I am borrowing a harmonic balancer puller, but haven't picked it up yet so I can remove the cover.
Also, the timing kit I picked up is a 38 tooth cam sprocket, with a 19 tooth crank sprocket. There is a racing/high performance version available with 50 cam and 25 crank tooth sprockets. Which one am I likely to find in my factory HP engine?
Thanks!
Re: 1973 400 4BBL HP Camshaft [Re: 340clone] #2695734
09/09/19 11:06 AM
09/09/19 11:06 AM
all engines in the same family will have the same tooth count on the sprockets which is 25/50 on a big block iirc. Cloyes brand has gotten some bad reviews lately
Re: 1973 400 4BBL HP Camshaft [Re: 340clone] #2695782
09/09/19 12:50 PM
09/09/19 12:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as mentioned the Purple shaft camshaft ( the basic one, first on the line ) is the correct one for 72/73 400 Magnums!!!... 74s are another story
