Re: HEI Conversion. Weak pickup coil?
[Re: Milan454]
#2695201
09/07/19 12:02 PM
09/07/19 12:02 PM
Posts: 19,307 north of coder
moparx
if i'm not mistaken, the HEI needs a constant 12 volts to run. are you feeding the coil from the ballast resistor ? that would cut the voltage down.
[Re: Milan454]
#2695307
09/07/19 09:09 PM
09/07/19 09:09 PM
RapidRobert
you may have a poor connection in the pickup leads/pickup coil. I would check the connections/terminals & if no go get another pickup.
[Re: Milan454]
#2695393
09/08/19 10:02 AM
09/08/19 10:02 AM
RapidRobert
Generally they are very trouble free, but once in a blue moon...
[Re: 500ciDuster]
#2695494
09/08/19 03:30 PM
09/08/19 03:30 PM
Posts: 19 Garagemahal
Milan454
Garagemahal
Just did one on an 81 Dodge truck and works great, make sure the module is has a good ground and the 12 volt wire that feeds the module should feed the + side on the coil The system works by substituting a GM pickup coil and spinning the GM distributor by hand. The new pu coil will be here today. Hope it's running by tonight! Thanks all!!! Milan
[Re: Milan454]
#2695677
09/09/19 09:10 AM
09/09/19 09:10 AM
Posts: 17,837 S.E. Michigan
ZIPPY
S.E. Michigan
I think you nailed it, that's probably the issue.
I've experienced intermittent, weak, and open circuit mopar pickup coils.
I really like the mopar distributor/hei module + better coil (latest favorite is the TFI) and no ballast on street oriented stuff where you don't need extra bells and whistles.
Rich H.
Esse Quam Videri
[Re: Milan454]
#2696487
09/11/19 11:01 AM
09/11/19 11:01 AM
RapidRobert
OE gap is .008" & you want that on the tightest tooth (they can vary) & as you said if the gap was high it certainly could have caused your dilemma. Just me I'd swap it back for a day to find out (I'd wanna know). But you are up & running & that's the main thing.
[Re: jlatessa]
#2696607
09/11/19 04:17 PM
09/11/19 04:17 PM
RapidRobert
& vac adv drastically changes (increases) the gap. If the gap is too big I could see where vac adv in use could cause a miss. Our South American member Nacho (who ain't posted in awhile as he has been too busy sunning himself on the beaches down there) reworked the plate to get that variance down to near nothing. Joe I would think getting the vanes equal would let you set the gap to the bare minimum. (I'm gonna rework the plate, just ain't got around to it yet). Maybe not an earthshattering (timing) difference but every bit counts & it keeps a person in the correct mindset of always searching for that edge (helps keep the furds/chebbies in their place).
[Re: RapidRobert]
#2696650
09/11/19 06:36 PM
09/11/19 06:36 PM
Posts: 1,817 South Bend
John Brown
South Bend
Years ago, several aftermarket companies used to sell ball bearing breaker plates, where the advance plate rotated around a center point, not from a point off to the side like many of the factory ones were. Probably worth looking into.
I noticed that also caused a problem with keeping dwell within specs when I was doing tune ups 50 years ago.
