Stage VI Head Porting
#2694884
09/06/19 09:04 AM
09/06/19 09:04 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
Hello everyone, Been awhile since I been on here. I am just looking for recomendations of someone who knows a lot about stage VI heads. My heads and intake have been ported but are still the standard ports. I am thinking maybe I need to open them up to max wedge and maybe there is some more room for improvement in other places. Also thinking of upgrading the cam and headers at the same time. Thanks
Matt
67' charger 499 RB
10.57 at 127
Re: Stage VI Head Porting
[Re: dragram440]
#2694913
09/06/19 10:30 AM
09/06/19 10:30 AM
JCFcuda
Dwayne Porter racing heads He has done many stage six heads straightens up most associated problems with them . He does excellent work .
I don't think you're going to be able to max wedge port those heads are pretty thin in the valve area spring cup .
Jim F
[Re: AndyF]
#2695093
09/06/19 11:17 PM
09/06/19 11:17 PM
dragram440
bigfork mn
I have actually been running these heads for the last 8 years so they have definately served me well so far. They were new when i bought them and had been totally worked over along with the intake. I was just hoping to get some more out of them. I have been head shopping and not finding anything much better performance wise with out breaking the bank! Thanks for the recomendations and i will be trying to get ahold of porter racing heads.
67' charger 499 RB
10.57 at 127
[Re: Mr.Yuck]
#2695156
09/07/19 10:10 AM
09/07/19 10:10 AM
dragram440
bigfork mn
Anyone have any experience with the Trick flow power port 270? Any idea what kind of power can be made with them? Looks like they flow better then the Indy EZ? I would guess my combo now is somewhere around 650 HP at the flywheel. I cant see spending a bunch on new heads to gain 20 HP. I would like to be in the 750 to 800 range but would assume I need to go to a ported 440-1 to get there.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2695216
09/07/19 12:26 PM
09/07/19 12:26 PM
Posts: 30,947 Oregon
AndyF
Anyone have any experience with the Trick flow power port 270? Any idea what kind of power can be made with them? Looks like they flow better then the Indy EZ? I would guess my combo now is somewhere around 650 HP at the flywheel. I cant see spending a bunch on new heads to gain 20 HP. I would like to be in the 750 to 800 range but would assume I need to go to a ported 440-1 to get there. 750 hp should be easy with the TF 270 heads if you're willing to give it some compression and cam. My pump gas 470 engine made 750 to 775 hp depending on which parts I was testing. That was with out of the box heads and 2 inch dyno headers. We ran 50/50 mix of unleaded premium and Hot Rod 102. I wrote a bunch of articles and posts on the 270 heads so just do a little reading and you'll get caught up. https://www.hotrod.com/articles/dyno-day-trick-flow-270-mopar-heads/
[Re: Mr.Yuck]
#2695249
09/07/19 03:06 PM
09/07/19 03:06 PM
dragram440
bigfork mn
Boosted doesn't fit my class and if I go boosted then it needs to make 1000+ and I need to change my Chassis.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2695250
09/07/19 03:08 PM
09/07/19 03:08 PM
dragram440
bigfork mn
My combo now is a 499 CI with 75 cc chambers is 12.52 to 1 compresson. The cam I am running now is a 272/275 @ .50 with .620 lift solid roller. 1050 Dominator with 5000 8" converter.
Any idea how these trick flow 270 compare to a heavily worked over stage VI?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2695265
09/07/19 04:38 PM
09/07/19 04:38 PM
Posts: 2,842 Pattison Texas
CSK
Pattison Texas
Any idea how these trick flow 270 compare to a heavily worked over stage VI? What does the car weigh ?
[Re: dragram440]
#2695293
09/07/19 07:41 PM
09/07/19 07:41 PM
AndyF
Any idea how these trick flow 270 compare to a heavily worked over stage VI? 0.620 lift is holding you back a bunch. Put some more lift in it and you might be surprised. The duration is probably roughly correct but it depends on the lobes being used. Best to have a chat with Dwayne before you start spending money. Could be as simple as picking up 50 hp by switching to a more serious camshaft.
[Re: BigBlockGTS]
#2695404
09/08/19 10:54 AM
09/08/19 10:54 AM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The Chapman heads used specially machined castings and used longer valves than std stage6’s. The main hurdle for big power with stage 6’s and bigger cubes is the lack of port area at the short turn under the valve spring. The head is very thin there. So, the smallish csa coupled with larger displacement means the motor is going to peak at a low-ish rpm. It’s easier to make hp when there’s enough port area to allow the torque curve to carry well into the upper rpms. If the OP’s heads are std port size, then there would(should) be a rather large increase in power going to a TF270 head and appropriately sized manifold. If the current combo has MW sized heads and manifold already, then the gains would be less........ and would depend on exactly how well the current heads are working. I can add this......... from an airflow standpoint........ I was involved with those heavily modded stage 6’s in the pics in this thread. Those were the best non-Chapman stage 6’s I’ve tested. The TF270’s outflow those. Re-read the first post- My heads and intake have been ported but are still the standard ports. The std port heads can have the opening made into MW size, but they won’t quite be the same as the actual MW stage 6’s. Those had relocated intake pushrod holes and used offset intake rockers(like what’s done with W2 and Victor heads) to allow the removal of the pinch. Trying to get a set of std stage 6’s to be “comparable” to TF270’s will cost more than buying the TF’s.
[Re: fast68plymouth]
#2695427
09/08/19 11:46 AM
09/08/19 11:46 AM
CSK
Pattison Texas
The Chapman heads used specially machined castings and used longer valves than std stage6’s. The main hurdle for big power with stage 6’s and bigger cubes is the lack of port area at the short turn under the valve spring. The head is very thin there. So, the smallish csa coupled with larger displacement means the motor is going to peak at a low-ish rpm. It’s easier to make hp when there’s enough port area to allow the torque curve to carry well into the upper rpms. If the OP’s heads are std port size, then there would(should) be a rather large increase in power going to a TF270 head and appropriately sized manifold. If the current combo has MW sized heads and manifold already, then the gains would be less........ and would depend on exactly how well the current heads are working. I can add this......... from an airflow standpoint........ I was involved with those heavily modded stage 6’s in the pics in this thread. Those were the best non-Chapman stage 6’s I’ve tested. The TF270’s outflow those. Re-read the first post- My heads and intake have been ported but are still the standard ports. The std port heads can have the opening made into MW size, but they won’t quite be the same as the actual MW stage 6’s. Those had relocated intake pushrod holes and used offset intake rockers(like what’s done with W2 and Victor heads) to allow the removal of the pinch. Trying to get a set of std stage 6’s to be “comparable” to TF270’s will cost more than buying the TF’s. Your Knowledge is amazing Dwayne
#2695676
09/09/19 09:03 AM
09/09/19 09:03 AM
dragram440
bigfork mn
That is actually good news then. I think My goal for the winter will be the Trick flow 270 and a good max wedge intake and possible cam change and I should be able to pick up some power. Is there room for improvement on porting the trick flows? Would you be interested in porting the Trick flows and helping me with a cam choice? Thank you for the advice! The Chapman heads used specially machined castings and used longer valves than std stage6’s. The main hurdle for big power with stage 6’s and bigger cubes is the lack of port area at the short turn under the valve spring. The head is very thin there. So, the smallish csa coupled with larger displacement means the motor is going to peak at a low-ish rpm. It’s easier to make hp when there’s enough port area to allow the torque curve to carry well into the upper rpms. If the OP’s heads are std port size, then there would(should) be a rather large increase in power going to a TF270 head and appropriately sized manifold. If the current combo has MW sized heads and manifold already, then the gains would be less........ and would depend on exactly how well the current heads are working. I can add this......... from an airflow standpoint........ I was involved with those heavily modded stage 6’s in the pics in this thread. Those were the best non-Chapman stage 6’s I’ve tested. The TF270’s outflow those. Re-read the first post- My heads and intake have been ported but are still the standard ports. The std port heads can have the opening made into MW size, but they won’t quite be the same as the actual MW stage 6’s. Those had relocated intake pushrod holes and used offset intake rockers(like what’s done with W2 and Victor heads) to allow the removal of the pinch. Trying to get a set of std stage 6’s to be “comparable” to TF270’s will cost more than buying the TF’s.
67' charger 499 RB
10.57 at 127
