Radio goes off when putting it into Reverse #2694465
09/04/19 07:41 PM
09/04/19 07:41 PM
South San Francisco, Ca
70sixpkrt Offline OP
I changed my transmission gear oil today and noticed that when I put it into Reverse my radio goes off and then on. It did blow the fuse once. It's a 4 speed. I was using Passon Perf gear oil and switched to 85W90 gear oil. I did add the trunk light harness that is behind the drivers side kick panel. I don't remember if it did this before adding the trunk light harness. The stereo is an aftermarket one which I put in about 20 years ago. Could it be a bad reverse switch at the tranny?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Radio goes off when putting it into Reverse [Re: 70sixpkrt] #2694509
09/04/19 10:49 PM
09/04/19 10:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Unless you have done some home made wiring the radio has nothing to do with the reverse light switch on the trans.
Re: Radio goes off when putting it into Reverse [Re: stumpy] #2694531
09/04/19 11:59 PM
09/04/19 11:59 PM
Andrewh Offline
Andrewh  Offline
does it do it consistently or is it intermittent?
Oddly I have the same issue, but it is an automatic in my coronet.
Re: Radio goes off when putting it into Reverse [Re: Andrewh] #2694533
09/05/19 12:05 AM
09/05/19 12:05 AM
It does it every time I put it in reverse. I believe it started right after I changed the tranny fluid today.
4-speed
3:54 Dana
Re: Radio goes off when putting it into Reverse [Re: 70sixpkrt] #2694639
09/05/19 10:32 AM
09/05/19 10:32 AM
Andrewh Offline
Andrewh  Offline
I have not dug into mine yet.
the only thing I can think of is a grounding issue.
when the reverse lights come on, the dash light for yours comes on too I believe.
depending on where you grounded your radio, would be the only thing in common with going into reverse as stumpy said, the wiring doesn't cross over like that.
Re: Radio goes off when putting it into Reverse [Re: 70sixpkrt] #2694684
09/05/19 12:30 PM
09/05/19 12:30 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I'd put the old fluid back in............
OK, I've never heard of such an issue before - pretty baffling!
Re: Radio goes off when putting it into Reverse [Re: Sunroofcuda] #2694686
09/05/19 12:43 PM
09/05/19 12:43 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Maybe the car thinks it's 2019. I think in one of my new cars the radio goes out in reverse to keep from distracting you.
2011 Drag Pak Challenger
Re: Radio goes off when putting it into Reverse [Re: rickseeman] #2694704
09/05/19 02:15 PM
09/05/19 02:15 PM
hooziewhatsit Offline
Does it do with the key at 'On' and the engine not running?
Re: Radio goes off when putting it into Reverse [Re: hooziewhatsit] #2694710
09/05/19 02:25 PM
09/05/19 02:25 PM
So I unplugged the plug to the reverse switch on the tranny. Car on accessory put it into reverse the radio stays on. No reverse light on the dash since it is unplugged. Hooked up a jumper wire from one female to the other female lead on the plug. Car on accessory the reverse light on the dash is on. Put it into reverse and the radio stayed on. To me it sounds like a bad back up light switch.
4-speed
3:54 Dana
Re: Radio goes off when putting it into Reverse [Re: 70sixpkrt] #2694751
09/05/19 05:59 PM
09/05/19 05:59 PM
Andrewh Offline
Andrewh  Offline
leave the jumper to keep the reverse light on without the switch plugged in, and start the car. see if the radio stays on or dies.
If it stays on, then shift into reverse and see if it still stays on.
Can you replicate it dying in accessory mode?
Re: Radio goes off when putting it into Reverse [Re: Andrewh] #2694761
09/05/19 06:39 PM
09/05/19 06:39 PM
I will try it again tomorrow with the car running. I have been doing this in accessory with the car off.
4-speed
3:54 Dana
Re: Radio goes off when putting it into Reverse [Re: 70sixpkrt] #2694901
09/06/19 10:04 AM
09/06/19 10:04 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The reverse light is on the same power line as the radio...
Sounds like the reverse light switch has an intermittent short to ground issue. EZ to check with a continuity light, unplug the connector on the trans switch, put the transmission in reverse and check if any continuity to ground from either terminal. I had the same issue with my 70 RR 4-speed... Later replacement switches from China are known to have issues..
Just my $0.02... wink
Re: Radio goes off when putting it into Reverse [Re: Sinitro] #2694945
09/06/19 11:56 AM
09/06/19 11:56 AM
Are you talking about checking the continuity with a test light on the switch or the connector?
I unplugged the plug and hooked up a test light. I put it in reverse. Grounded the test light and then touched the each terminal on the switch. No light from either side. Did the same with the plug. Light came on and radio stayed on. Bad back up switch?
4-speed
3:54 Dana
Re: Radio goes off when putting it into Reverse [Re: 70sixpkrt] #2695005
09/06/19 03:29 PM
09/06/19 03:29 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
When doing the test, ignition should be ON.. Ur test was correct for checking a shorted switch, but maybe its intermittant... When the trans is in reverse U should have continuity between the (2) switch terminals, but nothing to ground. But as I said previously the aftermarket OE replacement switches from China are strange, my suggestion would be REPLACE it. If U were in SoCal I would give U 1 I have about (5) spares....
Re: Radio goes off when putting it into Reverse [Re: Sinitro] #2695008
09/06/19 03:50 PM
09/06/19 03:50 PM
Thanks for the help. I'm getting a new switch tomorrow. I did do it with the ignition on. The switch is about 15 years old.
4-speed
3:54 Dana
Re: Radio goes off when putting it into Reverse [Re: Sinitro] #2695500
09/08/19 04:02 PM
09/08/19 04:02 PM
So I got a new back up switch yesterday. Plugged the plug to the new switch and pressed the ball bearing. The reverse light went on and the radio stayed on. I touched the switch to the trans for a ground and pressed the ball bearing. Reverse light went on and the radio stayed on. Looks like it was the switch. Thanks Sinitro. up
Now to pull the switch out without removing the shifter mechanism is a different story.
4-speed
3:54 Dana
Re: Radio goes off when putting it into Reverse [Re: 70sixpkrt] #2695803
09/09/19 02:13 PM
09/09/19 02:13 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Nice...
Happy to assist..
Hope all works out.. cool
