LA 360/727 into '94 Dakota...
#2694343
09/04/19 01:16 PM
09/04/19 01:16 PM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
Found a nice little truck with a bad 3.9 for cheap. Just happen to have a low mileage '77 360/727 combo on hand. Any mounts available for this swap? IIRC, LA engines won't accept Magnum mounts and most folks are swapping Magnums into older vehicles, not vice-versa. Just spitballin' here... Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: LA 360/727 into '94 Dakota...
[Re: I_bleed_MOPAR]
#2694377
09/04/19 02:25 PM
09/04/19 02:25 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: I_bleed_MOPAR]
#2694407
09/04/19 04:14 PM
09/04/19 04:14 PM
Posts: 129 SE Indiana
kowalski440
SE Indiana
Schumacher HAD what you need.They WERE Pricey, though (maybe why they were discontinued!).
Last edited by kowalski440; 09/05/19 07:45 AM. Reason: Reflecting next poster's reply to my original wording.
[Re: kowalski440]
#2694482
09/04/19 08:50 PM
09/04/19 08:50 PM
I_bleed_MOPAR
Buford, GA
Afraid of that but just looked and says discontinued. Tim
[Re: kenworth_goose]
#2694592
09/05/19 07:50 AM
09/05/19 07:50 AM
kowalski440
SE Indiana
Great tips! I need to file this info away... I've done the swap a few times. I use truck brackets and mounts and fab a box on each side of the frame and I always move the engine and trans. back to the firewall. They actually handle much better when you move the engine back. If I remember right it's 2 1/2 inches back. I use 3/16 plate to make the boxes for the mounts. I put slots in them just like the trucks. It;s a very easy job if you can weld.
#2694668
09/05/19 11:50 AM
09/05/19 11:50 AM
I_bleed_MOPAR
Buford, GA
I've done the swap a few times. I use truck brackets and mounts and fab a box on each side of the frame and I always move the engine and trans. back to the firewall. They actually handle much better when you move the engine back. If I remember right it's 2 1/2 inches back. I use 3/16 plate to make the boxes for the mounts. I put slots in them just like the trucks. It;s a very easy job if you can weld. Now, that's what I was looking for. Thanks, k w g. Tim
[Re: I_bleed_MOPAR]
#2694823
09/05/19 11:07 PM
09/05/19 11:07 PM
Posts: 2,046 ky.
kenworth_goose
ky.
I've done the swap a few times. I use truck brackets and mounts and fab a box on each side of the frame and I always move the engine and trans. back to the firewall. They actually handle much better when you move the engine back. If I remember right it's 2 1/2 inches back. I use 3/16 plate to make the boxes for the mounts. I put slots in them just like the trucks. It;s a very easy job if you can weld. Now, that's what I was looking for. Thanks, k w g. Tim You are welcome!
