Re: Putting Bushings in Lifter Bores
[Re: Convertcuda]
#2693227
08/31/19 06:37 PM
08/31/19 06:37 PM
Posts: 4,206 New York
polyspheric
New York
3 common reasons: 1. change the lifter diameter 2. correct tappet bore misalignment 3. use a keyed roller lifter with special bushings to avoid use of tie bars
Boffin Emeritus
[Re: Stanton]
#2693443
09/01/19 01:35 PM
09/01/19 01:35 PM
polyspheric
New York
just how far out could they be ?
Enough to eat a cam lobe every time it's built
Boffin Emeritus
[Re: AndyF]
#2693458
09/01/19 03:53 PM
09/01/19 03:53 PM
Posts: 8,861 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
. But if what he is saying is correct then the lifters bores would've been machined on a CNC rather than cast. So unless the CNC program was defective, the lifter bores should be in the correct location. The same should apply to original iron factory blocks. While not "CNC" in those days, the machining process would still have been automated enough to ensure a high degree of accuracy. If the machining was "out" on one block, chances are it would have been out on the next fifty or so until a block hit inspection and the problem was discovered/resolved. Even then, there would have been a min/max tolerance - just like oversize lifters or bearings.. I'm still not buying the severity of lifter bore to cam alignment.
[Re: Stanton]
#2693586
09/02/19 09:27 AM
09/02/19 09:27 AM
polyspheric
New York
You don't have to buy it, I'm not selling it.
If the alignment is correct (45° from vertical and parallel to the cylinder in both axes) the placement of the bore may still be off. An error along the crank axis is harmless unless a substantial portion of the tappet face is off the cam lobe. Never heard of it. An error across the crank axis will not be destructive (unless fairly large), but it will advance or retard the valve operation by changing the point at which the lobe's rotation reaches the tappet. Probably more common than suspected since there are no definitive symptoms except slight bump is the CCP/torque curve. If both banks are wrong in the same direction (block shifts in the fixture), move the cam to correct. Impossible to correct if the error is "handed" (left and right banks are wrong in opposite directions). If the tappet bore alignment is tilted w/r/t the cylinder axis across the crank axis it will misalign the pushrod, and may not change the event timing points. The dangerous one is where the tappet bore alignment is tilted w/r/t the cylinder axis front to rear, causing edge contact between the tappet face and lobe. The parts will eat each other, how quickly depends on the magnitude of the error, spring tension, etc. This was a big BBC problem decades ago.
Boffin Emeritus
[Re: Stanton]
#2693651
09/02/19 02:15 PM
09/02/19 02:15 PM
Posts: 2,175 Duloc
The Shadow
Duloc
. But if what he is saying is correct then the lifters bores would've been machined on a CNC rather than cast. So unless the CNC program was defective, the lifter bores should be in the correct location. The same should apply to original iron factory blocks. While not "CNC" in those days, the machining process would still have been automated enough to ensure a high degree of accuracy. If the machining was "out" on one block, chances are it would have been out on the next fifty or so until a block hit inspection and the problem was discovered/resolved. Even then, there would have been a min/max tolerance - just like oversize lifters or bearings.. I'm still not buying the severity of lifter bore to cam alignment. Completely wrong. Machining is horrendous on old blocks
