Msd Hemi 6 ignition?? #2693137
08/31/19 12:22 PM
08/31/19 12:22 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Do they work on 09 and up.
They changed to reluctor wheel to 64 tooth.
Would like to know if MSD has an upgrade?
Matt
Re: Msd Hemi 6 ignition?? [Re: MattW] #2693139
08/31/19 12:25 PM
08/31/19 12:25 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
When I talked to MSD directly, their tech were unaware and said "they changed the reluctor wheel?". Same response when I spoke with someone at the Nats in the vendor Midway. The LS motors changed wheels around the same time and MSD offers an upgrade to their LS boxes, so their technology is there. We need more people putting bugs in their ears about it.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Msd Hemi 6 ignition?? [Re: A39Coronet] #2693140
08/31/19 12:38 PM
08/31/19 12:38 PM
USA
hudsonhornet7x Offline
USA
There is a fellow on Facebook who has proven it works, BUT you have to change a few things first:
He has a 6.4 hemi running on the MSD hemi 6 box along with a cascar intake and a carb. I believe he had to pull the crank, change our the reluctor wheel to a 32 tooth unit, change the crank sensor to a 32 tooth unit, and more than likely lock out the vvt.
I have seen a video of it running. If I can I will post a link for you:
https://www.facebook.com/joe.hlavaty.31/videos/2841419459217875/
Re: Msd Hemi 6 ignition?? [Re: hudsonhornet7x] #2693173
08/31/19 02:34 PM
08/31/19 02:34 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Thx for the responses
Its for a dyno only use.
I was thinking of mounting the 32 tooth reluctor wheel on the dampener and using the pick up.
Should work
MSD SHOULD offer it!! I believe its just a programming thing and done.
Re: Msd Hemi 6 ignition?? [Re: MattW] #2699802
09/22/19 11:29 AM
09/22/19 11:29 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
I've seen the LS 6014 Box used on the newer Hemis, need to change the Cam sensor to the GM one.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
