70 RR Distribution block- leak? #2692635
08/29/19 02:46 PM
08/29/19 02:46 PM
New Mexico
JMCFAN Online content OP
JMCFAN  Online Content OP
New Mexico
Brand new Dist Block.... leaking from bottom bolt...? fix?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR Distribution block- leak? [Re: JMCFAN] #2692661
08/29/19 04:23 PM
08/29/19 04:23 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I just bought one and it leaks as well. It leaks from the top on mine. Chinese junk. I was plumbing in a water heater and went through five 3” brass nipples and they all leaked no mater how much pipe dope and Teflon tape I used. Went back a got 4” and First two worked. Poor quality control.
Re: 70 RR Distribution block- leak? [Re: fastmark] #2692713
08/29/19 08:43 PM
08/29/19 08:43 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Just finished an all new brake system on my 70 Charger. The reman master cylinder is leaking down the inside of the firewall onto the floor pan. I guess I get to take it out this weekend
to see what the issue is. I did use a repop distribution valve.....so far no leaks. However, i have not driven the car yet.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 RR Distribution block- leak? [Re: JMCFAN] #2692715
08/29/19 08:50 PM
08/29/19 08:50 PM
I'd try another plug & if that didn't do it I'd search for the strongest sealant I could find (to contain 1500+ psi), maybe JB weld it.
