1/4 mile pass question! #2692122
08/27/19 11:51 PM
08/27/19 11:51 PM
Oak Harbor, WA
W
Wicked49670dart Offline OP
W
Oak Harbor, WA
Hey guys have a couple of questions. I put new Hoosiers 29.5x10.50x15 slicks on my car took it to the track and have a issue of the car swaying back an fourth slightly past the 1/8th mile mark. I have 12.5 psi in both tires. The car ran 110 mph/1/8th and 125 mph in the1/4 on motor. I was going to spray my single stage 350 shot but did not want to take the change on wrecking the car, so ran it on nitrous 6.01@116 1/8th. The car had the same issue. I have check all 4 shocks, front and rear suspension I can't find any issues. Is it possible there is not enough air psi in the rear tires? I have 30 passes on then car never had this issue and the only things I changed was rear tires, had MT ET streets with tubes and now Hoosiers slicks with tubes and these are not stiff sidewall tires. Any Ideas? Thanks Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: 1/4 mile pass question! [Re: Wicked49670dart] #2692123
08/27/19 11:56 PM
08/27/19 11:56 PM
Are these radials or bias ply slicks?
If radials probably their to low on the pressure, if not radials I would call Hoosiers west (559-405(maybe 408?)4612 or Hoosier factory 574784-3152) and ask them about their recommendations scope up
Are the new tires on the same wheels as the M/T where on? If not look closely at the new wheels and their fitment to the axles and brake drums also as well as the pressures twocents
Re: 1/4 mile pass question! [Re: Cab_Burge] #2692126
08/28/19 12:08 AM
08/28/19 12:08 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
Hi, these are bias ply slicks, brand new . I did call Hoosier tech line and he said to try 12 psi! These tires are on the same rims the MT were on.
Re: 1/4 mile pass question! [Re: Wicked49670dart] #2692133
08/28/19 12:51 AM
08/28/19 12:51 AM
AZ
squirrel Offline
squirrel  Offline
AZ
hold the steering wheel still, let the rear end waggle back and forth, and enjoy the ride!
that's how slicks are
You can start with 15 psi and work your way to lower pressure if they spin at that high of pressure.
btw I run 20 psi in the 9x29 slicks on my altered wheelbase chevy. Hooks ok, and less waggling
Re: 1/4 mile pass question! [Re: squirrel] #2692147
08/28/19 06:32 AM
08/28/19 06:32 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Sounds like you have radials on the front
Re: 1/4 mile pass question! [Re: FastmOp] #2692151
08/28/19 06:48 AM
08/28/19 06:48 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
How much does the car weigh? The only times I ever had that happen was when I went too low on air pressure in the rear tires. If this is basically stock weight, I wouldn't go down on pressure. You will probably end up between 13 and 15 to get you back to where a stiff sidewall worked.
Re: 1/4 mile pass question! [Re: sgcuda] #2692156
08/28/19 07:23 AM
08/28/19 07:23 AM
Keymar, MD
DusterKid Online content
DusterKid  Online Content
Keymar, MD
As other have stated, go up in air pressure. Sometimes after your slicks get a good many runs on them the car will start to feel different, its because the sidewalls are getting weak. Going up in air pressure is an easy fix. The Hoosiers you got might be a softer sidewall than the MT thus the reasoning you need to go up in air pressure.
Re: 1/4 mile pass question! [Re: DusterKid] #2692162
08/28/19 07:47 AM
08/28/19 07:47 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Curious as to what tires you run up front ? On my 63 street car I run a 215/70-15 radial tire up front. Its not as fast as its a 10.70 car on good days but I used to run Hoosier QTP tires on the rear that were 29 x 10.5 and they are a bias tire. I also would get some sway/walking in the traps. So one day I tried 30 x 9 Hoosier radial slicks and what a difference. Heck now and can let go of the steering wheel in the traps as the car goes nice and straight with no walk or sway. And I believe it was from me mixing a front radial tire to a rear bias. Now I run about 18 psi in the radial slicks and I love them because the car hooks good on them and goes nice and straight. Ron
Re: 1/4 mile pass question! [Re: 383man] #2692186
08/28/19 09:12 AM
08/28/19 09:12 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
Thanks guys for the info, front tires are MT 26x7.50x15 bias tires which are the 8 ply version with 35 psi. Car weighs 3400 pounds with me. I use comp engineering 3 way shocks set to 90/10. What would be a better shock to run? Would it be better with shock set at 70/30 or 60/40? My 60ft that I just ran was 1.35 on nitrous with the 12.5 psi in those new Hoosiers! Thanks for the help!Matt
Re: 1/4 mile pass question! [Re: Wicked49670dart] #2692198
08/28/19 09:36 AM
08/28/19 09:36 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Did you measure the circumference of the tires? If they are more than 1/4" different you will get some swaying.
Re: 1/4 mile pass question! [Re: Wicked49670dart] #2692326
08/28/19 02:42 PM
08/28/19 02:42 PM
Originally Posted by Wicked49670dart
Thanks guys for the info, front tires are MT 26x7.50x15 bias tires which are the 8 ply version with 35 psi. Car weighs 3400 pounds with me. I use comp engineering 3 way shocks set to 90/10. What would be a better shock to run? Would it be better with shock set at 70/30 or 60/40? My 60ft that I just ran was 1.35 on nitrous with the 12.5 psi in those new Hoosiers! Thanks for the help! Matt
the only way to find out what works best on YOUR car is to test each of those settings wrench grin AKA aside you may need to change the shock settings(front and back) depending on track conditions shruggy
I have wrench up
Re: 1/4 mile pass question! [Re: Cab_Burge] #2692331
08/28/19 02:57 PM
08/28/19 02:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check the diameter on each tire
wave
Re: 1/4 mile pass question! [Re: MR_P_BODY] #2692425
08/28/19 09:26 PM
08/28/19 09:26 PM
Oak Harbor, WA
W
W
Oak Harbor, WA
Check both tires one measures 96.0 and the other 95 7/8! Hoosiers advertises 96.0. this is at 13 psi.
Re: 1/4 mile pass question! [Re: Wicked49670dart] #2692431
08/28/19 09:36 PM
08/28/19 09:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Tires aside, the 110 mph 1/8 doesn't jive with the 125 mph 1/4. Might want to find out why before you spay through a 1/4.
Re: 1/4 mile pass question! [Re: BSB67] #2692438
08/28/19 09:55 PM
08/28/19 09:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Put some more air in them. I'd bet 14.0-15.0. Smaller the tire the more air. I run 13.5-14.0 in my 10.5Wx31.
Doug
Re: 1/4 mile pass question! [Re: Wicked49670dart] #2692458
08/28/19 11:13 PM
08/28/19 11:13 PM
Many measuring tools don't read exactly the same like every other tool of the same type and even the same brand shock shruggy work
I don't loan out my air pressure gauges, torque wrenches, micrometer and many other tools like that after having three low pressure Moroso tire gauges ruined by people I loaned them to at the track whiney realcrazy
I don't learn quickly on some things, huh whistling
My message is use your tire gauge only to find out what pressures the new tires like on your car wrench scope up
Re: 1/4 mile pass question! [Re: Wicked49670dart] #2692625
08/29/19 01:58 PM
08/29/19 01:58 PM
an8sec70cuda Offline
The swaying is typical of bias ply slicks, regardless of the type of tire is on the front. The only time mine has swayed bad on bias plies was when the pressure was too low.
On a heavy car, you'll probably be around 14-15 psi for them to be happy.
So your car only picks up 15 mph on the back half N/A? And then only gained 6 mph at the 1/8 on a 350 hit???? You have some issues going on here.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1/4 mile pass question! [Re: an8sec70cuda] #2692782
08/30/19 01:42 AM
08/30/19 01:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree as I do remember my low 12 high 11 car from the 70's walking some in the traps and I had bias slicks and bias up front. But I have seen mixing radial and bias make it seem even worse as I know it did on my car. Course radial slicks also run more pressure then bias also which can help. I know my 63 is much better with the radial slicks then the bias were and I do run radials up front. But I think you are right as even if I had bias tires up front I believe it would still have walked some in the traps. Because as you stated it is typical some of the bias slick from what I have seen and heard. Ron
