Straight Boot Spark Plug Wires 440 RB #2692060
08/27/19 08:17 PM
08/27/19 08:17 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
I tried to get Taylor 409 wires but they came with 45 degree angle boots. Who makes a good set of straight boot wires for an Ebody with a 440 RB?
Re: Straight Boot Spark Plug Wires 440 RB [Re: Chip] #2692061
08/27/19 08:19 PM
08/27/19 08:19 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Firecore wires have the boots you need up
Gus beer
64 Plymouth Savoy
Dana 60
Re: Straight Boot Spark Plug Wires 440 RB [Re: fourgearsavoy] #2692069
08/27/19 08:45 PM
08/27/19 08:45 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
On Mancini the 8.5 wires show a angle boot?
Re: Straight Boot Spark Plug Wires 440 RB [Re: Chip] #2692115
08/27/19 11:02 PM
08/27/19 11:02 PM
I wouldn't use a straight spark plug boot on any Mopar B or RB motor in a B,E or A body with stock exhaust manifolds or headers unless I absolutely had to twocents I don't use them on any if my race cars either unless they fit better shruggy
Re: Straight Boot Spark Plug Wires 440 RB [Re: Cab_Burge] #2692143
08/28/19 04:55 AM
08/28/19 04:55 AM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
I tried the angle plug wires and the spark plug wires end up touching my headers. I am running my wires away from the top of the valve covers so it is easy to pull the valve covers.
Why don't you like straight boot plug ends?
Re: Straight Boot Spark Plug Wires 440 RB [Re: Chip] #2692304
08/28/19 01:36 PM
08/28/19 01:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Straight Boot Spark Plug Wires 440 RB [Re: Chip] #2692318
08/28/19 02:23 PM
08/28/19 02:23 PM
The wires fit better on most BB cars with 90 degree boots shruggy
Most after market heads made today except 440 Source have angle plugs which help on the wire fittings but most headers can use the 90 degree boots better also on most of the plugs work scope
IHTHs thumbs
Re: Straight Boot Spark Plug Wires 440 RB [Re: Cab_Burge] #2692354
08/28/19 04:44 PM
08/28/19 04:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We have run Taylo Spiro pros for 440s for years.Mine has 2 inch TTIS my kids 413 had 2 1/8 tubes.Last set on mine were like 15 years old or older just looked tacky.Only wire thats close is 7 and Irun a heat boot on it.We run holders fro Summit that bolt to lower VC bolts and hold wires up and away.When you take the lower bolts out the entire holder comes off with wires attached.Been on close to 20 years.Rocky
Chrysler Firepower
Re: Straight Boot Spark Plug Wires 440 RB [Re: Cab_Burge] #2692421
08/28/19 09:15 PM
08/28/19 09:15 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Thanks for your feedback guys!
Re: Straight Boot Spark Plug Wires 440 RB [Re: Chip] #2692594
08/29/19 11:49 AM
08/29/19 11:49 AM
NW Illinois
MoonshineMattK Offline
NW Illinois
I use universal cut to length spark plug wire sets. They can be ordered with straight or angled ends.
I also have been wrapping my headers for almost 20 years. Never had a boot melt with wrapped headers
Re: Straight Boot Spark Plug Wires 440 RB [Re: MoonshineMattK] #2692632
08/29/19 02:18 PM
08/29/19 02:18 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
You can get MSD wires w/ straight boots.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Straight Boot Spark Plug Wires 440 RB [Re: an8sec70cuda] #2692678
08/29/19 05:43 PM
08/29/19 05:43 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I made my own over 20 years ago. Got some Taylor wire and cut each to length required then add the ends and boots required. A bit time consuming but they fit/look great still. It was gonna be tough to find a pre-made set to it my BB A-body w/headers. Never have had a single wire issue. If I was to buy a set today, I would send this set to Firecore and have him duplicate them with his wire and ends.
Re: Straight Boot Spark Plug Wires 440 RB [Re: an8sec70cuda] #2693239
08/31/19 07:21 PM
08/31/19 07:21 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Thats what I did...got MSD 8.5 with straights!
