Removing oxidation on brushed aluminum #2691349
08/25/19 08:14 PM
08/25/19 08:14 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
I have a brushed aluminum radiator and it developed some oxidation over the past couple of years while sitting. I tried a paper towel soaked with vinegar lying on it for a short time. Also tried scrubbing it with a cloth soaked in vinegar. No luck with either. Any suggestions on cleaning this off?
Re: Removing oxidation on brushed aluminum [Re: Vert] #2691352
08/25/19 08:26 PM
08/25/19 08:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Oxidation causes pitting.
You may be able to polish to a fresh surface, but no cleaner removes pitting.
If it was anodized & just the coating wore through, you may be able to have it anodized again?
Re: Removing oxidation on brushed aluminum [Re: Alaskan_TA] #2691371
08/25/19 09:28 PM
08/25/19 09:28 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Thanks for your help. I may Flitz it and then hit with Eastwood Diamond Clear. It'll be polished then instead of brushed tho...
Re: Removing oxidation on brushed aluminum [Re: Vert] #2691388
08/25/19 10:08 PM
08/25/19 10:08 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
A Scotchbrite pad will clean it off and keep it brushed looking. Just scrub in the direction of the brush marks. They make different grit pads for finer or more aggressive scrubbing.
Re: Removing oxidation on brushed aluminum [Re: Sniper] #2691391
08/25/19 10:22 PM
08/25/19 10:22 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Try Colonel Brassy . I used it on old ozidized wheels and they are very presentable.
A mothers power ball chucked in a variable speed drill will help.
Re: Removing oxidation on brushed aluminum [Re: srt] #2691537
08/26/19 12:00 PM
08/26/19 12:00 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
iagree A Scotchbrite pad will clean it up fast.
Re: Removing oxidation on brushed aluminum [Re: burdar] #2691550
08/26/19 12:22 PM
08/26/19 12:22 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
"OO" steel wool works great also on bare aluminum.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Removing oxidation on brushed aluminum [Re: hemi-itis] #2691622
08/26/19 04:04 PM
08/26/19 04:04 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Rubber sanding block with a fine grit paper and some water. Sand left to right to make it uniform. Little car wax when your done to seal it.
Re: Removing oxidation on brushed aluminum [Re: Neil] #2692042
08/27/19 07:37 PM
08/27/19 07:37 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I tried all these suggestions on my Power Wagon's anodized grille but nothing brought back any shine. My mechanic suggested Oven Cleaner so I tried that then scrubbed with the scotch brite and that actually brought back some shine.
Facts are stubborn things.
Re: Removing oxidation on brushed aluminum [Re: larrymopar360] #2692197
08/28/19 09:34 AM
08/28/19 09:34 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
To polish anodized aluminum, you first have to remove the anodizing. The oven cleaner you used, stripped off the anodizing so the aluminum could be polished.
Re: Removing oxidation on brushed aluminum [Re: Vert] #2692303
08/28/19 01:33 PM
08/28/19 01:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Non coated wheel cleaner will remove the oxidation / stains and brighten the aluminum but it will not remove pitting. Works well on carbs and intakes beer
Re: Removing oxidation on brushed aluminum [Re: TJP] #2692316
08/28/19 02:22 PM
08/28/19 02:22 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Autosol . . . best damn stuff ! Will take some elbow grease too, but it will be awesome !!!
http://www.autosol.com/product_p/1824.htm
Re: Removing oxidation on brushed aluminum [Re: Vert] #2692731
08/29/19 09:28 PM
08/29/19 09:28 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Thanks for all the replies. Its brushed, but I don't think its anodized. Hopefully I can brush, sand off the oxidation, brush the "brushed" pattern back in, and clearcoat it.
Re: Removing oxidation on brushed aluminum [Re: Vert] #2692850
08/30/19 11:11 AM
08/30/19 11:11 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I use gray scotchbrite pads to get the brushed look. It's very similar to how it's done in manufacturing but they have big powered wheels of the stuff.
- Stu Harmon
Re: Removing oxidation on brushed aluminum [Re: feets] #2693369
09/01/19 09:28 AM
09/01/19 09:28 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
In the air conditioning trade, we use some caustic cleaners called nu-brite, and alka-brite for cleaning and brightening aluminum condensers. It works really well for car parts as well, cleaned up the belly pan of my viper with it.
Re: Removing oxidation on brushed aluminum [Re: Uberpube] #2693996
09/03/19 02:59 PM
09/03/19 02:59 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Non painted aluminum wheel cleaner should work great, it brings back heads a manifolds also.
Have a great day
Iowan
"obsolete is neat"
