W-200 kick-down linkage #2691107
08/25/19 06:22 AM
08/25/19 06:22 AM
Norway
General 68 Offline OP
Norway
Hello
Just got a '77 W-200 truck for cheap. It is missing the upper part of the kick-down linkage. The bellcrank on the intake is there. The Edelbrock carb needs a part on the throttle lever to attach the missing linkage to.
Can you see exactly what is missing? A photo of the evaquation would help a lot😀
Attached is a picture showing the situation as it is now.
Re: W-200 kick-down linkage [Re: General 68] #2691116
08/25/19 07:34 AM
08/25/19 07:34 AM
RWG75
RWG75
Here's a generic picture of the 3 piece kick down showing the bit your missing. They do repop the entire setup for some crazy amount of money but dunno about buying individual pieces. If yer asking about the missing bit for the carb, can't help ya with that because thermoquad. Once upon a time edlebrock did offer a throttle stud adapter piece for mopars but as I recall it was crap.
Re: W-200 kick-down linkage [Re: ] #2691151
08/25/19 10:26 AM
08/25/19 10:26 AM
Norway
Norway
Thanks. That looks more like the setup on the passenger car 318/904 I have in the garage. The up-rod on my truck (see pic) looks quite different.
Re: W-200 kick-down linkage [Re: General 68] #2691167
08/25/19 10:54 AM
08/25/19 10:54 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
If my truck was here I could take a picture for you, but it's not. The edelbrock adapter set doesn't work very well at all, when it's all adjusted right, you end up with a very stiff gas pedal compared to stock.
With my new engine setup I am going to be using the Lokar cable.
Re: W-200 kick-down linkage [Re: Uberpube] #2691199
08/25/19 11:54 AM
08/25/19 11:54 AM
moparx Offline
moparx  Offline
please use the buchillion setup instead. you will be happier with it.
my opinion on the lokar is not good.
i have changed over a dozen lokar setups back to the factory or the buchillion. lokar is just a "fitzall, hope it works" GM adaptation that uses cheap, bicycle type cable and somewhat flimsy brackets.
as the cable stretches, you will be constantly fiddling with your adjustment.
just my experience and opinion. your mileage may vary [but i'm not the only one with this opinion]
beer
Re: W-200 kick-down linkage [Re: Uberpube] #2691200
08/25/19 11:57 AM
08/25/19 11:57 AM
Alberta
440_Offroader Offline
Alberta
I put on the BPE kickdown cable kit on my powerwagon and it works great. https://www.bouchillonperformance.com/meta-product-kickdown-cable-kit
Re: W-200 kick-down linkage [Re: General 68] #2691201
08/25/19 11:57 AM
08/25/19 11:57 AM
moparx Offline
moparx  Offline
let me look in my stash of "stuff". i may have your missing part[s]
if i do, i'll send 'em to you, gratis. [i know you are not "local". grin]
beer
Re: W-200 kick-down linkage [Re: moparx] #2691219
08/25/19 12:40 PM
08/25/19 12:40 PM
Norway
Norway
Wow!😀 Can't get better than that👍😀 You speak Norwegian?😀
Re: W-200 kick-down linkage [Re: ] #2691225
08/25/19 01:22 PM
08/25/19 01:22 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
xLURKxDOGx over at FABO has what you are looking for. Looks like you have the single kick down rod, you just need the bracket assembly. You’ll also need the Holley linkage adapter which you can get from Summitt. The kick down stud is fairly easy to find.
Abe Lincoln
Re: W-200 kick-down linkage [Re: moparx] #2691227
08/25/19 01:36 PM
08/25/19 01:36 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Thanks for the heads up on that, hopefully they have something I can adapt to the proflo xt efi intake setup.
Re: W-200 kick-down linkage [Re: Uberpube] #2691230
08/25/19 01:49 PM
08/25/19 01:49 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Might have to do some creative fabbing
Abe Lincoln
Re: W-200 kick-down linkage [Re: General 68] #2691261
08/25/19 03:54 PM
08/25/19 03:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The Edelbrock lever extension is #1481 and the pic below shows the linkage installation. You'll need the stud, top link and spring.
Re: W-200 kick-down linkage [Re: John_Kunkel] #2691267
08/25/19 04:12 PM
08/25/19 04:12 PM
Norway
Norway
Thanks!
I understand that I need the throttle rod, the spring and the bracket with the small link that connects the rod? AND the throttle lever piece!?
Re: W-200 kick-down linkage [Re: General 68] #2691525
08/26/19 11:32 AM
08/26/19 11:32 AM
moparx Offline
moparx  Offline
i didn't get a chance to look yesterday. sorry !
i'll do that this afternoon after i get back from the doc's office.
i'll post either way with what i find in my "stuff"
beer
Re: W-200 kick-down linkage [Re: moparx] #2691526
08/26/19 11:40 AM
08/26/19 11:40 AM
Norway
Norway
Don't rush - no problem beer
Re: W-200 kick-down linkage [Re: General 68] #2691538
08/26/19 12:03 PM
08/26/19 12:03 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i'd just put the lokar kickdown and throttle cable on it.
i'm happy with the ones on my W200
Re: W-200 kick-down linkage [Re: General 68] #2692597
08/29/19 11:53 AM
08/29/19 11:53 AM
moparx Offline
moparx  Offline
general, sorry for the delay. i believe i have the bellcrank and the rod. as the engine is on the rack, and there is lots of "stuff" around in front of the rack, i think i can get it off maybe this weekend.
can you get an approximate length of the rod needed from the bellcrank area ?
and no, i can't speak Norwegian. i have a tough enough time with english. biggrin
beer
Re: W-200 kick-down linkage [Re: moparx] #2692982
08/30/19 06:12 PM
08/30/19 06:12 PM
Norway
Norway
Hi! 😀 Great! I can take some meassures tomorrow. Might be from rear intake bolt for referances as there is no bellcrank there to meassure from😂
