Edelbrock Heads Now Cheaper Than Stealths #2690287
08/22/19 10:44 AM
08/22/19 10:44 AM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
The price of the 84cc Edelbrock E Street heads has been reduced to $1112.85. With Summit's $100 off deal if you spend more than $1000 and free shipping this brings the price down to $1012.85, cheaper than a pair of $1000 440 Source heads since 440 Source doesn't offer free shipping.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: 67Satty] #2690297
08/22/19 10:51 AM
08/22/19 10:51 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Life is good for the bb mopar guys! 440 source will still have its niche with the stock look.
2 kids and a dog
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: 67Satty] #2690312
08/22/19 11:45 AM
08/22/19 11:45 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Not bad at all up
If I remember correctly I paid 1050 for my RPM heads, but that was a long time ago and I held out for the 10% discount.
The almost* stock appearance of the Stealth head will give it continued success.
*Lack of a heat crossover is obvious from the top
Rich H.
Esse Quam Videri
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: 67Satty] #2690442
08/22/19 07:42 PM
08/22/19 07:42 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
How about the 75 cc head?
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: BSB67] #2690452
08/22/19 08:11 PM
08/22/19 08:11 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Not bad
https://www.summitracing.com/parts/edl-5090
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: bee1971] #2690462
08/22/19 08:46 PM
08/22/19 08:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Nice. Thanks.
Almost want to buy them just to have them.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: BSB67] #2690467
08/22/19 08:57 PM
08/22/19 08:57 PM
Kirkland, Washington
Pacnorthcuda Offline
Competition does wonderful things.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: 67Satty] #2690480
08/22/19 09:45 PM
08/22/19 09:45 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Are the E street heads better than the Trick Flow 240 heads?
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: Digger73] #2690489
08/22/19 10:46 PM
08/22/19 10:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Digger73 (Mike)
How do you measure better?
Power potential goes to TF 240.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: BSB67] #2690492
08/22/19 10:48 PM
08/22/19 10:48 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Just asking because they are the same price.
Digger73 (Mike)
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: Digger73] #2690495
08/22/19 10:54 PM
08/22/19 10:54 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Digger73 (Mike)
Thats a pair for the Edelbrocks,,,each for the TF240
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: CSK] #2690500
08/22/19 11:12 PM
08/22/19 11:12 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
My bad...
Digger73 (Mike)
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: Digger73] #2690514
08/23/19 12:30 AM
08/23/19 12:30 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Digger73 (Mike)
The tfs 240 head price is per head.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: 4406bbl] #2690531
08/23/19 06:50 AM
08/23/19 06:50 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Does 440Source charge sales tax? I know that Summit does.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: sgcuda] #2690636
08/23/19 01:49 PM
08/23/19 01:49 PM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
If I'm not mistaken, the E street head has a powder metal seat in it. Which Edelbrock told be you can only run a hydraulic flat tappet cam and nothing else or you would have to change the seats.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: stroked470] #2705552
10/10/19 02:40 PM
10/10/19 02:40 PM
Indiana
MFR440 Offline
MFR440  Offline
Indiana
Sorry for dragging up an older thread, but Mancini has deal going on the RPM heads for about $1350 a pair. Are they much better than the EZ‘s? I am in the planning stages of a pump gas 440 build and wondering if I should go ahead and pick these up or wait until I know better what will be going into my build.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: MFR440] #2705560
10/10/19 02:51 PM
10/10/19 02:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
“Better” than EZ’s??
Totally depends on what you’re trying to do with them.
I would say it like this......
The RPM heads that have gone through my shop needed less work to be “right” than the EZ heads.
And I’ve had many of both through the shop.
But I don’t really consider those direct competitors with each other.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: MFR440] #2705570
10/10/19 03:16 PM
10/10/19 03:16 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i think those edelbrock heads are the Mopar Performance RPM heads with straight plugs. just an FYI.
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: fast68plymouth] #2705696
10/10/19 09:15 PM
10/10/19 09:15 PM
Indiana
MFR440 Offline
MFR440  Offline
Indiana
Thanks for the reply - you are a guru for sure!👍
But what if I don’t know what I’m tying to do with them? 😄
My options are pretty wide open. I have a 440 block with a forged crank, stock rods, and some decent pistons...but I am also considering a 440-Source stroker kit. Are the RPM’s overkill for a mild build? It just seemed like a really good deal, and I am wondering if I might be able to “grow” into them later. 😉
Re: Edelbrock Heads Now Cheaper Than Stealths [Re: MFR440] #2705758
10/11/19 01:36 AM
10/11/19 01:36 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
[quote=MFR440
My options are pretty wide open. I have a 440 block with a forged crank, stock rods, and some decent pistons...but I am also considering a 440-Source stroker kit. Are the RPM’s overkill for a mild build? It just seemed like a really good deal, and I am wondering if I might be able to “grow” into them later. 😉 [/quote]
if youre considering a Source kit, i'd look at better rods. Rods are the most stressed part of any motor, why anyone would go cheap on rods is beyond me. When they fail, the damage is 20 x more than the money saved buying the cheap rubbish. I have personally seen 3x rod failures of Source rods, plus there have been a few on Facebook posts. Spend the money where it counts & sleep easier.
