3500 Dodge Ram Woes #2689522
08/19/19 07:50 PM
08/19/19 07:50 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
New 3500 Cummins diesel Ram truck with 7012 miles on it puts up a nice DEF alarm warning.
150 miles and it goes into 5mph limp mode.
I was 6.5 hours away last night. I only thought Duramax's had this problem and Cummins diesels were fool proof. Now i'm nervous its going to happen over and over.
Needed a Nox sensor. Why?
Re: 3500 Dodge Ram Woes [Re: Sammy] #2689526
08/19/19 08:05 PM
08/19/19 08:05 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Are you sure your def tank level isn’t to low?
Do you have a code reader that will clear code?
Do you know what relay(s) you need to jumper to get you 150 more miles (on one key cycle)?
Hit up a Cummins forum, it’s a modern diesel you need to be prepared!
Red
Re: 3500 Dodge Ram Woes [Re: BIGGERED] #2689528
08/19/19 08:08 PM
08/19/19 08:08 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Def refill intervals on modern diesels tend to follow oil change intervals. Depending on your duty cycle it could be time to refill!
Red
Re: 3500 Dodge Ram Woes [Re: BIGGERED] #2689563
08/19/19 09:48 PM
08/19/19 09:48 PM
Hastings MN
moparfrank Offline
moparfrank  Offline
Hastings MN
I have a 15 Ram 3500 that did that when it got below -15. It left me stranded in Iowa once and in Wisconsin twice both times on a weekend. I cured it with a EFILive tuner and programming. No problems since and I have over 130K on the clock. It had been to the dealer at least six times to be fixed.
Re: 3500 Dodge Ram Woes [Re: BIGGERED] #2689655
08/20/19 08:56 AM
08/20/19 08:56 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Red
I always keep it at 100% full.
It cleared the code once then 35 miles later, no engine light but said it was going to to 5mph after the next 150 miles.
I was 450+ miles away from home yesterday.
Re: 3500 Dodge Ram Woes [Re: moparfrank] #2689657
08/20/19 08:58 AM
08/20/19 08:58 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
It was 91 degrees yesterday and the truck has 7800 miles on it.
3rd time adding DEF Fluid.
Container of DEF was new and never opened.
This sure does not give me a warm a fuzzy feeling to drive long distances on the weekends now.
Re: 3500 Dodge Ram Woes [Re: Sammy] #2689699
08/20/19 11:14 AM
08/20/19 11:14 AM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Granted my truck is a 1500 Eco Diesel but there is a way to jumper a relay to get you out of limp mode if you reach the end of the count down
Red
Re: 3500 Dodge Ram Woes [Re: BIGGERED] #2689706
08/20/19 11:44 AM
08/20/19 11:44 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Red
I'd like to know how to do it.
I was told you can only do it once with a hand held code remover.
Re: 3500 Dodge Ram Woes [Re: Sammy] #2689726
08/20/19 01:04 PM
08/20/19 01:04 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Red
I was digging on the Cummins forums and there was mention of letting your def tank level drop a bit as when you continually top it off the system thinks you are not using any DEF.
Something to consider!
Red
Re: 3500 Dodge Ram Woes [Re: BIGGERED] #2689749
08/20/19 02:32 PM
08/20/19 02:32 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Red
Red
Diesel tech says there is a shelf life once added to your DEF tank. If you're not driving it a lot and putting a load on the engine, theres a great possibility that the DEF fluid is getting old and contaminating the system causing error codes.
Just throwing this out there which does make sense. Truck isn't driven much at all.
Re: 3500 Dodge Ram Woes [Re: Sammy] #2689956
08/21/19 10:16 AM
08/21/19 10:16 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
It's a shame that deleting that crap on the newer trucks voids the warranty. It ought to extend it, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 3500 Dodge Ram Woes [Re: an8sec70cuda] #2690013
08/21/19 01:17 PM
08/21/19 01:17 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Like someone mentioned I would let the DEF tank get low so you can reduce the average age of what is in the def tank. We have had a few DEF pickup trucks here at my work and the DEF systems have given very little trouble. Each truck has had a DEF tank and heater replaced once in its life but beyond that no other problems. When we quit driving our ford truck every day it eventually came up with a contaminated DEF code that would come back as soon as you cleared it. It had a 1/2 tank of DEF so I topped it off with fresh and the problem hasn't come back. The 2016 chevy I use as my personal truck uses so little DEF with my driving that I worry about it getting old so when it says it is low(no gauge) I only put 2.5 gallons in it instead of the 5 it holds.
68 Barracuda Formula S 340
Re: 3500 Dodge Ram Woes [Re: Bad340fish] #2690051
08/21/19 03:33 PM
08/21/19 03:33 PM
ky.
K
kenworth_goose Offline
K
ky.
my new 2500 has just under 9k on it and I've put about 4 gallon in it so far and it's down to a 1/4 tank of def now and I just purchased 2 new jugs of fluid today. I haven't had any issues. I do let mine run down usually to around 1/2 before I top it off. I have read someplace that it's mostly water.
Re: 3500 Dodge Ram Woes [Re: kenworth_goose] #2690093
08/21/19 05:53 PM
08/21/19 05:53 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: 3500 Dodge Ram Woes [Re: Sammy] #2690135
08/21/19 09:13 PM
08/21/19 09:13 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
Keeping it full is your problem. I bought a new aerial fire truck at work (over $1M), and it was the first the department had with DEF. They "topped it off" 2-3 times a WEEK, so the level sensor never moved. Threw a code for a defective sensor and the entire tank had to be replaced under warranty. 6 weeks later, same thing. That's when we found the root cause. It's one of the many safeties required by the government to make sure you don't mess with the system. let it go down to AT LEAST 1/2 is what Cummins told us...
Re: 3500 Dodge Ram Woes [Re: kenworth_goose] #2690822
08/24/19 12:04 AM
08/24/19 12:04 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If you ever get stuck somewhere and run low, distilled water will get you on your way.
I won't own a diesel anything built after Oct 2003, and my preference is pre 1998. 1998 is when the low NOx software started and EGR started Oct 2003.
Kevin
Re: 3500 Dodge Ram Woes [Re: nuthinbutmopar] #2690840
08/24/19 08:10 AM
08/24/19 08:10 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
The last time I filled it right up to the top was when it was just above 1/4 tank.
I was towing when it went down.
Now 800 miles later driving with no trailer, the gauge hadn't moved.
I've been driving it every day since to get that gauge to come down some.
Re: 3500 Dodge Ram Woes [Re: kenworth_goose] #2691038
08/24/19 08:58 PM
08/24/19 08:58 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought it was mostly piss.
Re: 3500 Dodge Ram Woes [Re: Kern Dog] #2691044
08/24/19 09:12 PM
08/24/19 09:12 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Urea diluted with distilled water apparently which is why distilled water won't hurt it, at least in above freezing. Tap water will cause problems because of the various chemicals and minerals in it.
Kevin
Re: 3500 Dodge Ram Woes [Re: Kern Dog] #2691045
08/24/19 09:18 PM
08/24/19 09:18 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
That's what Urea is. Dried up piss. Sure gets expensive when you gotta buy it by the gallon.
