Re: An ODD 3.8 starter issue ???? [Re: moparx] #2689984
08/21/19 11:24 AM
08/21/19 11:24 AM
Doc open it up, you'll be OK
Re: An ODD 3.8 starter issue ???? [Re: moparx] #2690157
08/21/19 09:48 PM
08/21/19 09:48 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I think we used to be able to buy the contacts at NAPA back in the day, they were pretty cheap. Gene
Re: An ODD 3.8 starter issue ???? [Re: poorboy] #2690293
08/22/19 10:49 AM
08/22/19 10:49 AM
Florida STAYcation
dOOc Offline OP
The village idiot's idiot
dOOc  Offline OP
Florida STAYcation
pb... I called the local Napa ... no luck. I wish the other car was road worthy and I WOULD pull that starter out and apart.
Thx for the tips guys
Re: An ODD 3.8 starter issue ???? [Re: dOOc] #2691541
08/26/19 12:07 PM
08/26/19 12:07 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Make sure you have your "help I can,'t get up" button around yer nEcK stirthepot
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: An ODD 3.8 starter issue ???? [Re: hemi-itis] #2691560
08/26/19 12:50 PM
08/26/19 12:50 PM
Florida STAYcation
dOOc Offline OP
dOOc  Offline OP
Florida STAYcation
Thx fer the suggestion iTiS .... mopX is sending me a starter ... it should be here in 3 days .... so you send me your IVE FALLEN AND CANT GET UP alarm switch that you wore when you got stuck in the New Yack snow drift !
Re: An ODD 3.8 starter issue ???? [Re: dOOc] #2691840
08/27/19 08:08 AM
08/27/19 08:08 AM
IMGTX Offline
IMGTX  Offline
I have no doubt it is the contacts on your car but I have had problems with the new cars having bad ground cables. Especially the ones with the battery in the trunk like the Chargers.
If you suspect it to be a bad ground cable it is easy to diagnose. Put a Jumper cable from a good ground, like the shock tower ground, to the engine on a metal bracket, like the Alternator or power steering. If the problem goes away your set. Often the ground from the body to the engine is behind the engine. It gets corroded easily and isn't easy to see.
Just food for thought on some of the newer stuff with tiny ground wires.
Re: An ODD 3.8 starter issue ???? [Re: IMGTX] #2691847
08/27/19 08:26 AM
08/27/19 08:26 AM
Florida STAYcation
dOOc Offline OP
dOOc  Offline OP
Florida STAYcation
Thx U R ! ... I’ll check that out !!
Btw .... when it rains IT POURS !
Fedex dropped the ball BIG TIME ! The box was beat up and EMPTY of any contents!
And they KNEW THIS when the package arrived in Ocala on Thursday!!!
Re: An ODD 3.8 starter issue ???? [Re: dOOc] #2691935
08/27/19 01:19 PM
08/27/19 01:19 PM
moparx Offline
moparx  Offline
i inspected the contacts in the starter i sent DoC, and someone's been in there before, as the contacts are almost NEW !
however, i screwed up and forgot to include include an "adapter wire" for the solenoid, as this starter is a 97, and his is an 05.
the exciter wire connection changed in 2000. i don't like to hack on original harness ends unless absolutely necessary.
when i make these "adapters", i use factory ends and marine shrink wrap, so it is just a "plug-n-play", no hassle, no problame-o deal, and a swap over at any time is possible.
sorry 'bout that DoC.
beer
Re: An ODD 3.8 starter issue ???? [Re: dOOc] #2691944
08/27/19 01:32 PM
08/27/19 01:32 PM
hemi-itis Offline
hemi-itis  Offline
So what does FUDEX have to say now??
Re: An ODD 3.8 starter issue ???? [Re: moparx] #2692181
08/28/19 08:42 AM
08/28/19 08:42 AM
Florida STAYcation
dOOc Offline OP
dOOc  Offline OP
Florida STAYcation
Many THX to X of coder ! ... to hopefully end this roller coaster!
iTiS ..... it was kind of approved by the customer service rep that they - Elmer FUDex - lol - would pick up the cost of OVERNIGHTing a replacement but I hit ANUTTER stone wall with the sellers ... THEY needed to call FEDex to do this.
I’ll post a cut a cut and paste of their response... again - it’s obvious to me that their FIRST LANGUAGE is not English!
Re: An ODD 3.8 starter issue ???? [Re: dOOc] #2692183
08/28/19 08:50 AM
08/28/19 08:50 AM
Florida STAYcation
dOOc Offline OP
dOOc  Offline OP
Florida STAYcation
Oh my goodness !!
Re: An ODD 3.8 starter issue ???? [Re: dOOc] #2692184
08/28/19 08:56 AM
08/28/19 08:56 AM
Florida STAYcation
dOOc Offline OP
dOOc  Offline OP
Florida STAYcation
Oh my goodness X 999 ... !!
It is NOT a post office issue AT ALL ... it is still at the Fedex depot in Ocala. It has never been in USPS custody.
Wait ANUTTER 4 days for investigation THEN ANOTHER 10 days for delivery ?
Can you believe this ?
Re: An ODD 3.8 starter issue ???? [Re: dOOc] #2692276
08/28/19 11:58 AM
08/28/19 11:58 AM
moparx Offline
moparx  Offline
if you don't get my starter in 10 days, i'll eat it.
[anyone know what alUminEum tastes like ? confused] biggrin
beer
