1978;truck fuel sending unit screw heads #2689512
08/19/19 07:13 PM
08/19/19 07:13 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Rounded off.Tried a drill screw extractor called grabbit.no go.Any ideas.
Re: 1978;truck fuel sending unit screw heads [Re: chargers777] #2689544
08/19/19 08:39 PM
08/19/19 08:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Drill the screw heads off with a drill large enough the take the heads off without drilling in the threaded part of the screw. Remove the sending unit and there should be enough screw to get small vise grips on.
Re: 1978;truck fuel sending unit screw heads [Re: stumpy] #2689648
08/20/19 08:35 AM
08/20/19 08:35 AM
RWG75
RWG75
Take a dremel to the sides of the screw heads and make two flat surfaces across from each other. Grab the screw by those flats with a small vise grip. If all else fails, grind the screw heads completely away, remove the sender, grind the screw stubs flush then reclock the new sender and drill new holes. There's a metal ring cast in the plastic around the sender opening.
Re: 1978;truck fuel sending unit screw heads [Re: ] #2689690
08/20/19 10:59 AM
08/20/19 10:59 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I wouldn't recommend using a Dremel around a gas tank because of sparks. But if you are super careful it might be ok.
