904 Vent relocation and CSR shield
#2689379
08/19/19 01:18 PM
08/19/19 01:18 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I am wanting to re locate my transmission vent on my 904. The recommended locations I have seen would interfere with the CSR transmission shield that I run. I don't want to modify the shield at all in fear that it might not get re certified that way Is there any issue with locating the vent in the tail housing?
68 Barracuda Formula S 340
Re: 904 Vent relocation and CSR shield
[Re: scottb]
#2689426
08/19/19 03:11 PM
08/19/19 03:11 PM
Bad340fish
Tulsa OK
That is good to hear. However since this is street driven I wouldn't mind the vent being back farther from the hottest part of the exhaust. I had an overfill or over overheat situation last year where it barfed fluid it out of the vent and it caught fire on the headers on the side of the highway. Luckily there was zero damage and after it did that it never did it again.
[Re: J_BODY]
#2690015
08/21/19 01:27 PM
08/21/19 01:27 PM
Bad340fish
Tulsa OK
You could put the vent in the tail housing but keep it away from the parking gear. It could throw oil out the vent. I put in a short barbed fitting and ran a hose to a vented catch can. Good point, thanks! I run my CSR shield with the case vent..... I’ll see if I can conjure up a pict. I use a quick connect air hose fitting and run the line to a catch can That would be great Jay, thanks! I do like the idea of a catch can. If my car ever 100% didn't leak trans fluid I would worry about it. My 727 leaked just enough I topped it off before drag week each year lol.
[Re: J_BODY]
#2690140
08/21/19 09:22 PM
08/21/19 09:22 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
[Re: 440Jim]
#2690567
08/23/19 09:32 AM
08/23/19 09:32 AM
Bad340fish
Tulsa OK
Thank you for the replies and the pictures. I could swear my shield covers the case 100% with no room for a vent but I will check it out again before I do something.
[Re: Bad340fish]
#2690600
08/23/19 11:23 AM
08/23/19 11:23 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I did mine the same way that Jim shows(I used his pic for directions) EDIT this is for a 727.. I dont know if they are the same
