When ordering a 1968 or 1969 Charger back in the day, you could order factory hood mounted turn signals (option code 517 for 1968 and L31 for 1969) for a whopping $10.50 in 1968 and $10.80 in 1969. However, all ’69 Chargers equipped with the Special Edition (SE) package got these signals as standard equipment. If your car wasn’t equipped with factory hood mounted turn signals, the spots on the hood instead had black hood signal block off plates installed.
Read the whole story at Mopar Connection HERE:
