70's Steering Wheels #2688787
08/17/19 04:27 PM
08/17/19 04:27 PM
Paducah, KY USA Earth
jcruse64 Offline OP
jcruse64  Offline OP
I just picked up a green steering wheel for my '73 W200 crew, which has a green interior, but a black wheel. The new-to-me wheel is off a '76 and was a 2WD. It does not want to on the steering shaft. Was there a difference between the 2WD and 4WD steering columns that would not allow such a swap?? Neither steering wheel is keyed; neither is my steering column. I'd hate not to be able to use this, after looking for the last few years for a decent green wheel.
Thanks,
Joe
Re: 70's Steering Wheels [Re: jcruse64] #2688969
08/18/19 07:40 AM
08/18/19 07:40 AM
RWG75
RWG75
I've had issues where I'd pop the wheel off to do something and then couldn't get it back on - just too tight of a fit. If you're sure the spline count is right take a bit of sand paper wrapped around a bolt to the inside of the donor wheel. Just enough to knock the ridges down a little bit is all I've needed.
Re: 70's Steering Wheels [Re: ] #2688976
08/18/19 08:06 AM
08/18/19 08:06 AM
jcruse64 Offline OP
jcruse64  Offline OP
I'll give that a shot. Thanks!
Re: 70's Steering Wheels [Re: jcruse64] #2688992
08/18/19 09:09 AM
08/18/19 09:09 AM
south louisiana
lowell66dart Offline
south louisiana
I thought I read somewhere about the D and W truck columns being different as to spline count but I'm not sure. I do know on my 72 W200 I have to hold it perfectly straight to get that sucker to line up.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
