Page 4 of 11 1 2 3 4 5 6 10 11
Re: Hilborn EFI 512 Charger [Re: Bad340fish] #2688371
08/16/19 11:08 AM
08/16/19 11:08 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Originally Posted by Bad340fish
I am a little surprised the HP system can't at least do some kind of modification bank to bank, how different are your readings side to side?
The Dominator can read and tune from two O2 sensors. The HP is only one.
efiexpert.com
Re: Hilborn EFI 512 Charger [Re: Mopar_Rich] #2688451
08/16/19 03:11 PM
08/16/19 03:11 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
efiexpert.com
Yep but the left only or right only, or Both together averaged out.
Re: Hilborn EFI 512 Charger [Re: CSK] #2688453
08/16/19 03:14 PM
08/16/19 03:14 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Did some more Hood cutting, for right now I can live with this, it will have to do until I pay off my credit card LOL.
Re: Hilborn EFI 512 Charger [Re: CSK] #2701482
09/27/19 05:29 PM
09/27/19 05:29 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Working on TRYING to get the car ready for the Lone Star Mopar Fest in Baytown HRP, next weekend, I REALLY hope I can make it, bad health SUCKS.
Installed the Holley Dash That I got from Rich [fastman efi],, With the Indy single plane intake it had 4" vacuum in gear @ about 900 rpm, now @ 700,800 rpm it is about 9" with the Individual runner Hilborn EFI.
Re: Hilborn EFI 512 Charger [Re: CSK] #2701704
09/28/19 12:00 PM
09/28/19 12:00 PM
moparx Offline
moparx  Offline
that's a SIZEABLE increase in vacuum. shocked
and yes, bad health sucks. BIG time..............
beer
Re: Hilborn EFI 512 Charger [Re: CSK] #2701714
09/28/19 12:25 PM
09/28/19 12:25 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
It's a great car. I was very glad to help.
Re: Hilborn EFI 512 Charger [Re: CSK] #2701874
09/28/19 11:38 PM
09/28/19 11:38 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Looks slow! wink Now come visit Arizona!
Re: Hilborn EFI 512 Charger [Re: gsmopar] #2701876
09/28/19 11:49 PM
09/28/19 11:49 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Originally Posted by gsmopar
[quote=csk]Working on TRYING to get the car ready for the Lone Star Mopar Fest in Baytown HRP, next weekend, I REALLY hope I can make it, bad health SUCKS.
Its not as fast as your Charger but it does have A/C LOL, I would love to visit!!!!
Re: Hilborn EFI 512 Charger [Re: CSK] #2701880
09/29/19 12:15 AM
09/29/19 12:15 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Maybe consider a clear reverse cowl, best of both worlds
Re: Hilborn EFI 512 Charger [Re: Alchemi] #2701938
09/29/19 11:34 AM
09/29/19 11:34 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I hope you get it ready to hit the track!!
I’m really surprised at how the IR system calmed that cam down.
That’s amazing.
Where are you taking the vacuum reading from?
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2701984
09/29/19 01:31 PM
09/29/19 01:31 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
That’s amazing.
On the Indy, from the carb base large PCV connection, The Hilborn has 8 hoses under the throttle plates that go to a manifold block & that is where I took the reading & also where the MAP sensor gets its reading from. I also replace the fuel pump because running more pressure now, went to a Hellcat 470lph pump, it had a 255lph that was borderline on volume when running the carb, I tested the new pump & all is good on volume now.
Re: Hilborn EFI 512 Charger [Re: CSK] #2716166
11/15/19 06:17 PM
11/15/19 06:17 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Well I have missed three good track events because of not feeling well, BUT tonight going to do the 140ish mile round trip to Baytown, HRP, should be REALLY good air, will post results when I get home, if the Charger makes it LOL smile , EXITED !!!! gonna have fun no matter what
Re: Hilborn EFI 512 Charger [Re: CSK] #2716168
11/15/19 06:22 PM
11/15/19 06:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
Excellent!!
Hope it goes well for you up
Re: Hilborn EFI 512 Charger [Re: CSK] #2716188
11/15/19 07:05 PM
11/15/19 07:05 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Ni
efiexpert.com
The technology is fast enough and sophisticated enough that it can read each pulse as it goes by the sensor and know what cylinder fired it and adjust accordingly.
Kevin
Re: Hilborn EFI 512 Charger [Re: Twostick] #2716194
11/15/19 07:12 PM
11/15/19 07:12 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Can't wait for the results, good luck!
68 Barracuda Formula S 340
Re: Hilborn EFI 512 Charger [Re: Bad340fish] #2716280
11/16/19 01:37 AM
11/16/19 01:37 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Well I made it there & back, one pass, BAD multiple driver errors, car spun, went up against the rev limit for BOTH shifts, looking at the data log I need to do some AFR tuning,AFR was all over the place, needs to be driven WOT through the gears more,That was the 1st time I really hammered it, will post a video later of the pass 11.09 @ 123.4. 4050lb race weight, -750DA. but there was dew on my car & on the track high humidity ?? I need to get someone else to drive the car, I have gone WAY passed my abilities, no SNAP at all, very frustrated with myself. Thanks for the interest in my journey.
Re: Hilborn EFI 512 Charger [Re: CSK] #2716322
11/16/19 10:43 AM
11/16/19 10:43 AM
So. Burlington, Vt.
So. Burlington, Vt.
Well, at least you made it there and back.
Why only one pass?
Re: Hilborn EFI 512 Charger [Re: CSK] #2716352
11/16/19 12:02 PM
11/16/19 12:02 PM
moparx Offline
moparx  Offline
i had a hard week, and was down yesterday, so i well know how that is.
i would also want to know why only one pass, but you say you are way past your abilities ?
i know better than that ! plug away my man. you can do it !! up
beer
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2716356
11/16/19 12:10 PM
11/16/19 12:10 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Why only one pass?
Started feeling bad & dizzy . exhausted, I knew I had a long drive,through the middle of Houston Tx at night & the traffic NEVER stops, 70ish miles home, Just driving in these conditions is tough, add the 51 year old hotrod Charger to the mix & I really had no choice but to get home.
Re: Hilborn EFI 512 Charger [Re: moparx] #2716360
11/16/19 12:13 PM
11/16/19 12:13 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
beer
Thanks for the encouragement , hope you are better.
at least it did not go slower LOL, & with the stack efi the engine drives on the road like a stock 440 it is amazingly tame & smooth
