I'm installing a new moog idler arm on my cuda, and when I took the old one out, it had one washer on the top and nothing on the bottom. However, I noticed that the instructions say to install the washer on the bottom side if the kit only comes with one washer ( mine only came with one). Will this have any affect on the steering if it's installed on the top vs the bottom side due to the slightly different installed height of the idler arm? Or am I overthinking this, and its just a spacer?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
