Solid Trany Mount
#2687131
08/13/19 04:59 AM
08/13/19 04:59 AM
Posts: 76 MASSACHUSETTS
Chip
MASSACHUSETTS
I dropped my big block RB 775hp stroker engine in my 70 Barracuda this weekend.
When I got the car it had a 383 425hp engine with front aluminum motor plate and a stock style automatic 727 transmission mount with the rubber. That's it.
I now have added solid steel motor mounts (stock k-frame car) on both sides along with the same front motor plate. (no mid plate) I can not find a solid transmission mount.
I could just fabricate a solid transmission mount i guess.
What do you guys run for transmission mounts for the 727 auto?
Re: Solid Trany Mount
[Re: Chip]
#2687139
08/13/19 06:21 AM
08/13/19 06:21 AM
Posts: 4,457 Washington
madscientist
Washington
What do you guys run for transmission mounts for the 727 auto? I've always used a rubber mount under the transmission, even with solid front mounts or a motor plate. Never had any issues with it. I've always "heard" that solid mounts in all three potions would cause the transmission case to fracture. Can't say if that's true or not, and it probably isn't. I just never did it.
[Re: madscientist]
#2687147
08/13/19 08:03 AM
08/13/19 08:03 AM
Posts: 3,068 Michigan
A727Tflite
What do you guys run for transmission mounts for the 727 auto? I've always used a rubber mount under the transmission, even with solid front mounts or a motor plate. Never had any issues with it. I've always "heard" that solid mounts in all three potions would cause the transmission case to fracture. Can't say if that's true or not, and it probably isn't. I just never did it. Depending on chassis rigidity will determine how long it will last but in the majority of cases you will fracture the extensions housing.
[Re: Chip]
#2687149
08/13/19 08:10 AM
08/13/19 08:10 AM
Posts: 4,205 New York
polyspheric
New York
I remember reading a warning that if you use both a plate and steel mounts one or the other must be shimmed into place?
Yes, rubber or poly on the transmission.
Boffin Emeritus
[Re: jwb123]
#2687157
08/13/19 08:37 AM
08/13/19 08:37 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I have a front plate, fore/aft limiter, and a poly trans mount on my cuda. My road runner has a front plate, one stock motor mount as a fore/aft limiter, and a rubber trans mount.
A solid trans mount isn't a good idea.
[Re: SportF]
#2687197
08/13/19 11:21 AM
08/13/19 11:21 AM
RapidRobert
^^^ I remember that build/article! What apps would a person want to use a solid trans mount? I have one.
[Re: RapidRobert]
#2687203
08/13/19 11:36 AM
08/13/19 11:36 AM
an8sec70cuda
I've never used a solid trans mount, just always heard it was a bad idea b/c you need some flexibility there. Good friend of mine used a solid trans mount on a backhalf ladder bar Camaro, low 6 sec 1/8 mile car w/ solid front mounts. Broke the tailshaft housing off the powerglide. Put a rubber mount on it and no more problem.
[Re: Chip]
#2687443
08/13/19 09:22 PM
08/13/19 09:22 PM
RapidRobert
Now that you mentioned "poly" the one I have is a red one from energy suspension for an early A body. I had assumed it was solid tho it appears to be near rock hard just trying to move it by hand. So Poly is acceptable?
[Re: J_BODY]
#2687453
08/13/19 09:47 PM
08/13/19 09:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You can run a motor plate WITH a solid trans mount.. you will still get some flex(mainly from the body).. DONT run a motor plate AND a mid plate with a solid trans mount.. that will break a tail shaft... reason is that is giving it 3 points that are solid.. any flex will snap the trans ext
[Re: J_BODY]
#2687523
08/14/19 07:19 AM
08/14/19 07:19 AM
Posts: 1,211 Minn
SportF
Minn
Thats funny.... when I first met Al his big block 727 Duster had a motor plate and a solid trans mount. Never was an issue.
FWIW both my cars with motor plates have had poly trans mount. I’m a sheeple... Like a lot of things in life, this is like playing tiddely winks on the free way and living. You can do it, its just not a great idea.
