Grade 5 Or Grade 8 Intake Bolts
#2686162
08/09/19 10:33 PM
08/09/19 10:33 PM
Posts: 869 Keizer, Oregon U.S.A.
elmor353
Need to pick up some intake bolts for a 360. Leaning towards grade 5 bolts. Isn't grade 8 overkill for an intake manifold? Your thoughts would be appreciated.
Re: Grade 5 Or Grade 8 Intake Bolts
[Re: elmor353]
#2686236
08/10/19 09:41 AM
08/10/19 09:41 AM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
Grade 5 for sure. Cast iron and aluminum can’t handle grade 8 torques.
[Re: markz528]
#2686242
08/10/19 10:46 AM
08/10/19 10:46 AM
Posts: 16,117 Mesa, Arizona
dart4forte
Mesa, Arizona
The following specs apply to:
Chrysler Small Block, LA Series, 273 c.i.d. 318 c.i.d. 340 c.i.d. 360 c.i.d. Fastener Type Torque Specs Main Cap Bolts 85 ft.-lbs. Connecting Rod Bolts (Plain) 45 ft.-lbs. Cylinder Head Bolts, 273-318 85 ft.-lbs.* Cylinder Head Bolts, 340-360 95 ft.-lbs.* Rocker Shaft Bracket Bolts 17 ft.-lbs. Intake Manifold Bolts 35 ft.-lbs. Oil Pump Cover Bolt 95 in.-lbs. Oil Pump Attaching Bolt 35 ft.-lbs. Oil Pan Bolts 15 ft.-lbs. Cam Locking Bolt 35 ft.-lbs. Cam Thrust Plate Bolts 210 in.-lbs. Harmonic Damper Bolt 135 ft.-lbs. Flywheel/Flexplate Bolts 55 ft.-lbs. Flywheel Housing to Engine Block Bolts 50 ft.-lbs. Flexplate to Torque Converter Bolts 270 in.-lbs. Clutch Housing Bolts 30 ft.-lbs. Front Cover Bolts 30 ft.-lbs. Water Pump Bolts 30 ft.-lbs. *Follow factory torque sequence
Notes These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use aftermarket performance bolts like ARP's, you should follow the recommended torque specifications. Please note that some specifications are in inch-pounds, rather than foot-pounds. Read the chart carefully to prevent broken bolts due to excessive torque.
Abe Lincoln
[Re: elmor353]
#2686247
08/10/19 11:05 AM
08/10/19 11:05 AM
Posts: 953 Chicago
PurpleBeeper
Chicago
I'm with these guys all the way...grade 5. There's no need for grade 8 on an intake and Heaven forbid you break a bolt, grade 8's are a PIA to get out
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
