Squealing still after alignment??? #2686165
08/09/19 10:37 PM
08/09/19 10:37 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
My 72 Dart is still Squealing after alignment, It done fine before on mountain curves, put New leaf springs on, drove it & on some mountain curves it has light squealing, but on flat curves it don't, So I go to have a alignment & front raised up a little, seem like it went straight, rides a little smother, but drove it back up on the mountain & its still squealing around some curves,.. & I drove it just the same as I all way have before I put leaf springs on!.. The springs are in the holes, Could I over tighten the u bolts on one side & it do that?... He set the setting for everyday driving!.. Any suggestions?...
Re: Squealing still after alignment??? [Re: Hoop] #2686171
08/09/19 10:42 PM
08/09/19 10:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Maybe the new springs have changed the slop in the suspension and you are pushing too hard on the new more solid set up. I also would think for a cornering car you would want the front lower not higher. Over tightening the Ubolts won't effect the handling. You want them tight enough that the rear end won't move on the perches.
Re: Squealing still after alignment??? [Re: Hoop] #2686248
08/10/19 11:08 AM
08/10/19 11:08 AM
Chicago
PurpleBeeper Offline
Chicago
If you're sure it's in the leaf spring area, it would be a pain, but you could pull the bolts out and smear some more grease up in the eye holes.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Squealing still after alignment??? [Re: PurpleBeeper] #2686260
08/10/19 11:54 AM
08/10/19 11:54 AM
BDW Online content
BDW  Online Content
I had a squeaking issue after replacing the hangers and rear springs.
Drove me crazy until I took it all apart and found interference between the 2.
Once a ground a little on the hanger it solved the problem.
Re: Squealing still after alignment??? [Re: Hoop] #2686274
08/10/19 01:35 PM
08/10/19 01:35 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Are you talking about tires squealing or suspension squeaking? If it is tires squealing then Does it handle any different when it makes this noise? Does the front or rear of the car push you out? If you changed the spring rate significantly it can and will affect the handling. It's a balancing act between the front and rear.
Re: Squealing still after alignment??? [Re: GomangoCuda] #2686311
08/10/19 05:21 PM
08/10/19 05:21 PM
God's Country Maryland
GODSCOUNTRY340 Offline
You're going too fast in the turns.
Re: Squealing still after alignment??? [Re: GODSCOUNTRY340] #2686315
08/10/19 05:38 PM
08/10/19 05:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Does it have a Sure-Grip or even a spool? If so, tire squeal is very normal on hard & / or fast turns.
Re: Squealing still after alignment??? [Re: Hoop] #2686648
08/11/19 09:48 PM
08/11/19 09:48 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I saw on hear in tech archive you can't go by factory specs, don't anybody have anything to say on that???... So you can't go by the old repair books?
So the rear can't be off as long as its in the hole's?
Re: Squealing still after alignment??? [Re: Hoop] #2686717
08/12/19 06:50 AM
08/12/19 06:50 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I assume you mean tire scrub squealing? I was working on a clone Six pack Super Bee yesterday and installing the Dana from a complete rebuild. I dropped the springs out to paint them and noticed the right side spring perch had two thin shims in it. I assume someone had a four wheel alignment. It is a well done car. Maybe check the alignment on all four corners
Re: Squealing still after alignment??? [Re: fastmark] #2686808
08/12/19 10:46 AM
08/12/19 10:46 AM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
There is no rear alignment on that vehicle. If the rear is off the geometric centerline and thrust angle will be off. Alignment machine will show this. If it is off, the rear spring perch is broken, or loose. If the car has radial tires I set camber as close to zero degrees +/- 1/2 degree....try to get as much positive caster as possible. Usually hard to do if still has factory front suspension. FirmFeel.com has great parts. Toe-in 0 -1/32" in total.
Re: Squealing still after alignment??? [Re: 1969RR] #2686812
08/12/19 10:57 AM
08/12/19 10:57 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You can actually alter the rear alignment by using the shims mentioned in one of the above posts. Adding shims between the front spring hanger and the mounting boss on the car will effectively push the rear wheel on that same side towards the back of the car thus altering the relative position of both rear wheels to the front wheels slightly.
Re: Squealing still after alignment??? [Re: jbc426] #2686840
08/12/19 11:34 AM
08/12/19 11:34 AM
moparx Offline
moparx  Offline
the build quality back in those days was horrible. the rear could be in there located anywhere, with up to 1/2" variation from factory blueprints without having broken, or worn out parts.
very easy, but labor intensive, to relocate closer to specs by shims and slotting holes where needed.
measure closely [twice or more] before cutting [hole slotting, shimming] once.
beer
Re: Squealing still after alignment??? [Re: Hoop] #2686859
08/12/19 12:11 PM
08/12/19 12:11 PM
Are you pushing the car faster now than before the work?
If so your now making the tire work harder to go around the corners and it is talking to you maybe saying your on the edge, dude whistling shruggy
If your not going faster around the corners now something is not right with that work work scope
Let us know what you find out and do to take care of it thumbs
Re: Squealing still after alignment??? [Re: Cab_Burge] #2686922
08/12/19 03:45 PM
08/12/19 03:45 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I'm kind of with Cab on this, if everything is correct (big IF) are you going faster through those curves now?
What are your alignment specs? Everyday driving specs don't mean much to me. I'd like to see the angles and degrees. There are many, Many, MANY alignment places where an alignment consists of setting toe and nothing else. If this is the case with the shop you used, there are several ways your alignment could STILL be off, possibly by a lot, despite the fact you paid for and they claim it was aligned.
Re: Squealing still after alignment??? [Re: Hoop] #2696712
09/11/19 09:35 PM
09/11/19 09:35 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Well I been driving it & its steal doing it on 3 sharp curves, Its a short tire squeal or you could say a tire chirp, I took it back to wear I had alignment & he sead it seems fine & it just my tires, but if it my tires why did it not do it before, I know better then that, So I've been just driving it, its not as loud now, with music on you don't hear it. Something I am wondering about is can you over tighten leaf springs u bolts because they do look it to me???
Re: Squealing still after alignment??? [Re: Hoop] #2696718
09/11/19 09:39 PM
09/11/19 09:39 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Rare, but I will quote myself;
Quote
Re: Squealing still after alignment??? [Re: Hoop] #2696722
09/11/19 09:45 PM
09/11/19 09:45 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
More pics
Re: Squealing still after alignment??? [Re: Hoop] #2696723
09/11/19 09:47 PM
09/11/19 09:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
By the looks of that spring pack, I would suspect you may have one or more broken leafs. Even if the leafs are not broken, the ends of each spring could be dragging on the longer leaf above it, that could give you a squeak as the suspension moves up and down. If you jack the car up, and look at the ends of each spring leaf, you may be able to see scraping or wear marks on the longer leaf. Gene
Re: Squealing still after alignment??? [Re: poorboy] #2696732
09/11/19 09:58 PM
09/11/19 09:58 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
So new springs can be broken??? I hope not, lot of work putting them on!
Re: Squealing still after alignment??? [Re: Hoop] #2696738
09/11/19 10:20 PM
09/11/19 10:20 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Post a copy of the alignment sheet. That will show where this car is set at.
