Rubber master cylinder rod retainer
#2686044
08/09/19 01:57 PM
08/09/19 01:57 PM
Posts: 16,450 On the run…
BloFish
On the run…
I am installing a new dual master cylinder, Wagner R88783, for my Scarebird disc brake swap on my A100 and discovered the rubber retainer provided is significantly smaller than my rod. There is no groove on the rod, and the rod seems to fit in the cup of the master cylinder just fine without it. Is the rubber retainer necessary?
*My old single master cylinder did not have one installed. But it was replaced by the previous owner some 20 years ago.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: Rubber master cylinder rod retainer
[Re: GoodysGotaCuda]
#2686050
08/09/19 02:15 PM
08/09/19 02:15 PM
BloFish
On the run…
Then I will need a thinner push rod. When I force the rubber retainer on the rod, the overall diameter is larger than the master cylinder opening.
Thanks for the advice.
[Re: RapidRobert]
#2686051
08/09/19 02:18 PM
08/09/19 02:18 PM
BloFish
On the run…
std protocol for manual brakes is for the MC rear piston "thimble" to have a shallow circular recess about halfway down the "tapered" barrel for the neoprene nub to lock into & for the manual brake pushrod to have a narrowed shank near the end for you to slip the nub over/past the rounded end. this might not apply to MC's that lock the pushrod in place I can see the recess in the thimble, nut I still don’t think the rod will slip far enough into the rubber retainer to make any difference.
[Re: BloFish]
#2686055
08/09/19 02:26 PM
08/09/19 02:26 PM
RapidRobert
unless somehow the pushrod is locked in place as is, the neoprene nub has to be in that recess to retain the pushrod. EDIT & on your prior post I'm thinking wrong pushrod
[Re: RapidRobert]
#2686060
08/09/19 02:34 PM
08/09/19 02:34 PM
BloFish
On the run…
I assume that the pushrod is original to the van. Perhaps there is enough meat that I can hollow out the bushing to fit the rod, or remove the 1/4” of play out of the pedal to assure a tight fit.
[Re: BloFish]
#2686061
08/09/19 02:37 PM
08/09/19 02:37 PM
RapidRobert
stay after it & see if it looks like the MC or the pushrod or the nub needs to be changed/altered. EDIT I've just used a snip of vac line & cut a slight lengthwise groove in it like the ones that come with MC's have & slipped it over the round end but it sounds like something else is going on on your deal. Post how it turns out.
#2686079
08/09/19 04:19 PM
08/09/19 04:19 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I would [and do] definitely run one. It's not needed until you shuffle your feet while driving and just pop "up" the brake pedal.
Not if there's a brake light switch at the rear end of the pushrod.
[Re: John_Kunkel]
#2686126
08/09/19 08:50 PM
08/09/19 08:50 PM
BloFish
On the run…
Not if there's a brake light switch at the rear end of the pushrod. There is, and I removed the excess play in the rod. Fells nice and snug, no room for error
