Mini tubbed, springs reloctaed, tire suggestions please:
#2685730
08/08/19 03:14 PM
08/08/19 03:14 PM
Posts: 1,541 USA
hudsonhornet7x
USA
As I complete the fabrication of my 68 Charger, I am figuring out how wide of a wheel I can go, along with how big of a tire.
So here is what I have: 68 Charger with tubs widened to the frame rails. Springs relocated to the frame rails as well.
I have not picked a rear end, so that width can be whatever I need.
Going to run 15" wheels, but do not have any idea how wide I can go with rim width and also how big of a tire can I run. I figure to ask some of you guys who have done these modifications and see what you are running. Pictures of your car are a bonus, nothing like seeing a fat tire mopar.
I would like my car to sit somewhere like this if possible ( I know I can't go to this extreme with a mini tub, but something close to this would be awesome) : Love the fat and tall look.
Re: Mini tubbed, springs reloctaed, tire suggestions please:
[Re: one bad fish]
#2685747
08/08/19 04:41 PM
08/08/19 04:41 PM
Posts: 20,644 So Near, Yet So Far
topside
So Near, Yet So Far
My advice would be to find the wheel you want, see what sizes are available, and same with tires. A 12" wide wheel is pretty big, mine have 4.0" BS and the car runs 13x31s. Drag car. Then, I'd suggest buying what you want and mocking up the rearend & etc around them. A couple photos...
[Re: hudsonhornet7x]
#2685763
08/08/19 05:49 PM
08/08/19 05:49 PM
Posts: 2,842 Pattison Texas
CSK
Pattison Texas
My 68 Charger has 15x10, 4 7/8 Back space,325-50-15 MT drag radials, stock width S60, Stock tubs & spring location, it is as large as you can go stock, it will rub the inside when pulling in my steep angle driveway, this should give you a reference with your inner tubs moved.
[Re: Stanton]
#2685793
08/08/19 07:09 PM
08/08/19 07:09 PM
topside
So Near, Yet So Far
Yeah, I should add that anything taller than about 29" will rub the front of the wheel opening flange. You can either pie-slice (to keep the flange) there, or cut it away, depending on how stock you want the area to look. I did the pie-cut on another Duster and it bought me about 1.25". It would just take a 30" tire, but tight. Charger probably has more room. Measure, measure, measure. Spacing the rear axle back a bit can buy you some room, being that your springs are at the rails.
[Re: topside]
#2685796
08/08/19 07:12 PM
08/08/19 07:12 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Yeah, I should add that anything taller than about 29" will rub the front of the wheel opening flange. You can either pie-slice (to keep the flange) there, or cut it away, depending on how stock you want the area to look. I did the pie-cut on another Duster and it bought me about 1.25". It would just take a 30" tire, but tight. Charger probably has more room. Measure, measure, measure. Spacing the rear axle back a bit can buy you some room, being that your springs are at the rails. Do you happen to have a picture for reference? I am interested to see. Thank you.
#2685805
08/08/19 07:55 PM
08/08/19 07:55 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
With my 68 Satellite I spaced the front spring hanger back 1/4" , plate , I can now run the MT PBR 29.5x10.5R15 which is 30"tall . I have a 15x10 , 5.5"BS stock spring and tub . Without the spacer a MT 296/65R15 (30.5") hooked the dogleg when i lifted in the lights
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: theraif]
#2685976
08/09/19 11:14 AM
08/09/19 11:14 AM
Posts: 5,094 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Ultimately the easiest thing to do is to find the widest tire and wheel that will fit and then buy them first. Your only real backspace considerations need to be what you will see from the outside...some like little backspace and a short rear...personally I like a rear that would be a little shorter than stock and then sticking with a near 50/50 wheel offset...maybe even more back space when using a wide wheel. Depending on your wheel well opening 30" or so tall is the limit without modifying the 1/4's. I run a 30" tall tire (275/60/17) on a 9.5" wheel with 5.5" of backspace on a stock wheel well on my 70 Satellite. I have the leaf springs moved back 3/4"...I think the section width of the tire is about 11.75". The springs are SS springs and I have the front hangers flipped upside down...I also installed a 1 1/2" lowering block between the spring and the rearend perch... It is stuffed about as full as you can go without relocating the inner wheel houses and the springs. Buy the wheels and tires you want...mock them up where they fit in the wheel well the best... This will determine the width you will need for the rear...don't forget to figure in for rotor and/or drum thickness... Then decide if you want to use leaf springs or go with a 3 link or something... Ride height can be modified using leafs by installing the front perch up or down and also by using sliders at the rear instead of shackles... This how mine sets with about 150#'s of stereo equipment in the trunk...
...FAFO...
