Re: Automotive machine shops WTH?
[Re: an8sec70cuda]
#2685622
08/08/19 09:57 AM
08/08/19 09:57 AM
Posts: 9,092 Rogue River, OR
Jeremiah
Rogue River, OR
That is an interesting perspective Chip. Thanks for sharing it from the machinists' point of view. My 511 went through three shops before it found a fellow that follows through with his projects because a) he enjoys accomplishment and b) he likes money. My kind of guy. That and he has a sense of humor so it ends up being a pretty fun experience. I feel pretty fortunate after getting jacked around eight ways. Now that I said that he will probably retire and dissapear to a far off island where golf courses are a plenty and hemi valve trian issues are not discussed lol.
[Re: an8sec70cuda]
#2685642
08/08/19 10:50 AM
08/08/19 10:50 AM
Posts: 4,457 Washington
madscientist
Washington
I got started building engines after getting screwed over by a shop on the first 440 I put in my cuda in 1998. After that, it was all me b/c I wanted to know exactly what I was getting. It's too easy for someone to give you a completely built engine and lie about what's in it.
I never understood why someone tells you a week and then it ends up being 2 months for no apparent reason. I ran a small machine shop for about 6 years and loved doing it. Always stuck to the price quoted and stuck w/ the time frame religiously. If it had to be adjusted, I let the customer know ahead of time. Always treated people like I wanted to be treated b/c I knew all too well how bad it is to be screwed around w/ on an expensive and important piece of your pride and joy. We didn't assemble engines there for liability reasons, but I'd do them at home on my own time. I found out real quick how expensive the equipment is and how cheap customers are...especially in this area. When you have a $45k head surfacing machine (cheaper floor demo model), charge $30-$50 per head, and people complain about that...it gets frustrating. Had to send cranks out to 2 other shops to get turned b/c we didn't have a crank grinder. Talk about an expensive piece of equipment right there.
Most of our bread and butter was rebuilding stock heads off anything and everything for local garages and dealerships. A lot of newer stuff can't be rebuilt, it's all just replaced w/ new. Pretty soon all of your business will be people rebuilding older vehicles and, of course, race engines. Here there isn't enough of either to keep a shop going (10-15 years ago anyway), so I went back to school and changed careers. The shop I was at closed 6 months after I left. Of course now there are more and more shops closing so it would seem a GOOD shop could do pretty well. I'll run into some of my old customers and they'll ask when I'm gonna open my own shop. I say as soon as I win the lottery and have money to burn. Even had a fellow racer and business owner offer to buy the equipment and set up a shop for me to run, but that never worked out. There are only 2 good local shops around here now and I'm fortunate to be friends w/ them. My stuff usually gets done quick and I try hard not to be the nightmare customer that used to do that kind of work. I have bought stuff here and there so I only have to have minimal work sent to the machine shop. The best thing is to have your own dial bore gauge and micrometers so you can check what your shop machined for you. So true. Most people think building engines is a money maker. It's a money loser. Most of the customers are whined little babies, who are so cheap it's not funny. Everybody is a winner and wants a sponsorship, because of course, they will drive so much business your way you'll get wealthy. Yep. The cost of equipment is horrendous. Tooling is just as bad or worse. I can't tell you how many times I've sat on completed work that wasn't picked up. And certainly wasn't paid for. Since companies like Jegs and Summit will sell parts cheaper than most engine builders, the little profit there was in parts is gone. Can't have the shop make any money. Of course, when the [censored] doesn't fit, or isn't what it's said to be, the customer wants ME to call THEM and deal with it. How does that work? Now I'm taking money out of my pocket to build your engine. Then you have the good old Internet. Obviously the customer is the smartest dude on the planet. They never make a mistake. Your junk converter can make my engine look slow, but the customer has no problem walking through the pits bitching about how [censored] my engine is. And then they go on the web and tell everyone how slow your engine is. Of course, when the truth comes out, there is no repeat ions made. No walking through the pits and telling everyone it was a junk converter that was killing ET and not the engine. No web posting doing the same. There is no such thing as a loyal customer, especially in this game. You have the customer who thinks slamming an engine together takes an hour or two, and a competent engine builder who charges 1k (or more) is still making barely above poverty wages for that money. Of course, the home hobby engine assembler doesn't know how to degree a cam, fit cam bearings, check piston to valve clearance or even own a set of micrometers, let alone a set of standards. So they have no way of knowing anything about what they do. And when said assembler has issues, like the engine is an underachiever, the same old, same old happens again. It had to be the [censored] machinist who is stupid and can't do anything. Doesn't matter that the valves are hitting the Pistons because the cam wasn't degreed correctly, or the file fit rings are butting or a dozen other issues. It gets old listening to guys bitching about not being able to find a machinist. If you are so smart, and so good, open your own shop. Like the guy above, when you get tired of picking [censored] with the chickens, you'll get smart and walk away. It's silly that grown men actually thinks it's a privilege to build their engine and we should be thankful we get to do it, and we should just do it because it's so damn fun. Like anything else, it's a job. That's it. Just my .02 from personal experience. Glad I'm done with it.
[Re: madscientist]
#2685670
08/08/19 11:45 AM
08/08/19 11:45 AM
Posts: 1,237 North Central, Indiana
Roughbird72
Most of our bread and butter was rebuilding stock heads off anything and everything for local garages and dealerships. A lot of newer stuff can't be rebuilt, it's all just replaced w/ new. Pretty soon all of your business will be people rebuilding older vehicles and, of course, race engines. Here there isn't enough of either to keep a shop going (10-15 years ago anyway), so I went back to school and changed careers. The shop I was at closed 6 months after I left. Of course now there are more and more shops closing so it would seem a GOOD shop could do pretty well. I'll run into some of my old customers and they'll ask when I'm gonna open my own shop. I say as soon as I win the lottery and have money to burn. Even had a fellow racer and business owner offer to buy the equipment and set up a shop for me to run, but that never worked out. There are only 2 good local shops around here now and I'm fortunate to be friends w/ them. My stuff usually gets done quick and I try hard not to be the nightmare customer that used to do that kind of work. I have bought stuff here and there so I only have to have minimal work sent to the machine shop. The best thing is to have your own dial bore gauge and micrometers so you can check what your shop machined for you. So true. Most people think building engines is a money maker. It's a money loser. Most of the customers are whined little babies, who are so cheap it's not funny. Everybody is a winner and wants a sponsorship, because of course, they will drive so much business your way you'll get wealthy. Yep. The cost of equipment is horrendous. Tooling is just as bad or worse. I can't tell you how many times I've sat on completed work that wasn't picked up. And certainly wasn't paid for. Since companies like Jegs and Summit will sell parts cheaper than most engine builders, the little profit there was in parts is gone. Can't have the shop make any money. Of course, when the [censored] doesn't fit, or isn't what it's said to be, the customer wants ME to call THEM and deal with it. How does that work? Now I'm taking money out of my pocket to build your engine. Then you have the good old Internet. Obviously the customer is the smartest dude on the planet. They never make a mistake. Your junk converter can make my engine look slow, but the customer has no problem walking through the pits bitching about how [censored] my engine is. And then they go on the web and tell everyone how slow your engine is. Of course, when the truth comes out, there is no repeat ions made. No walking through the pits and telling everyone it was a junk converter that was killing ET and not the engine. No web posting doing the same. There is no such thing as a loyal customer, especially in this game. You have the customer who thinks slamming an engine together takes an hour or two, and a competent engine builder who charges 1k (or more) is still making barely above poverty wages for that money. Of course, the home hobby engine assembler doesn't know how to degree a cam, fit cam bearings, check piston to valve clearance or even own a set of micrometers, let alone a set of standards. So they have no way of knowing anything about what they do. And when said assembler has issues, like the engine is an underachiever, the same old, same old happens again. It had to be the [censored] machinist who is stupid and can't do anything. Doesn't matter that the valves are hitting the Pistons because the cam wasn't degreed correctly, or the file fit rings are butting or a dozen other issues. It gets old listening to guys bitching about not being able to find a machinist. If you are so smart, and so good, open your own shop. Like the guy above, when you get tired of picking [censored] with the chickens, you'll get smart and walk away. It's silly that grown men actually thinks it's a privilege to build their engine and we should be thankful we get to do it, and we should just do it because it's so damn fun. Like anything else, it's a job. That's it. Just my .02 from personal experience. Glad I'm done with it. I believe it was said in a post a few years back about engine/chassis work. If the customer thinks you did a great job, a dozen people may hear about it. If the customer thinks you screwed him over, everybody hears about it.
72 Plymouth Roadrunner 11.08@123.25
[Re: bonefish]
#2685685
08/08/19 12:37 PM
08/08/19 12:37 PM
Posts: 20,645 So Near, Yet So Far
topside
So Near, Yet So Far
Against all odds, I've run into a couple of guys here in northern Idaho who I've been real happy with: One was Lee Sixt (now retired), who was half of the Beebe & Sixt TF deal back in the '60s. He just loved that I'd worked with Kent Fuller, I guess, but his work was spot-on, reasonably priced, and pretty much on time. The guy I've used since Lee retired is not inexpensive, but fanatical about detail & accuracy, and also pretty much on time, depending on how busy he is. My theory is to be friendly, respectful, but upfront about expectations, look around the shop, get the expected costs & timelines, and don't grind on the money. Only time that didn't work was with a well-known SoCal racer/engine guy, whose 1st build for me was excellent, but the 2nd was a $10,000 time-bomb that was horrible. The post-mortem on the thing (3 easy passes) was so full of screwed-up stuff that my buddies still want to kick his a** 20 years later.
[Re: 496 A-body]
#2685729
08/08/19 03:12 PM
08/08/19 03:12 PM
madscientist
Washington
So I go to pick up the align honed block today. A 2 guy shop, one guy was working on an engine torquing down a head, other guy standing there watching him. I say I'm there to pick up the block, let him know that he really misrepresented the cost and that this was a budget build and if he was upfront on what he was going to charge I would have found another source. The story changed, today he didn't claim that they charge per main cap, today they story was that they had to cut the caps to get the bore in spec and that drove the cost up. I found this very odd considering I bore gauged the main bore and found it was in spec, the reason I wanted it align honed was because the surface of the cap that mates to the block was not flat, it rocked a good bit on my surface plate and I replaced the factory torque to yield fasteners. I personally surface ground the mating surface of the caps making sure that the same amount was taken of each one relative to the radius. Pics below No offense, but I would not have line honed your block after you cut the caps. That's part of the line hone, if they need it. There is no way your surface plate cuts a cap like a dedicated cap cutter. You should have asked them how long it took to clean up the caps after you cut them. Again, no offense.
[Re: 496 A-body]
#2685739
08/08/19 03:55 PM
08/08/19 03:55 PM
Posts: 2,603 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
As far as pricing, charge what you need to charge to make money doing the job, just be honest. Don't tell someone that it is going to be $400 to bore and hone a block then blindside them with a $900 invoice WOW that guy is pricy! Not many blocks are worth $900.
2011 Drag Pak Challenger
[Re: madscientist]
#2685740
08/08/19 04:11 PM
08/08/19 04:11 PM
Posts: 369 Indy
496 A-body
Indy
Again, no offense. I think you misunderstood what I did, I cut them on a surface grinder and removed .0023 of material, just enough to make the surface uniform and consistent. A cap cutter may do better but being that they ones I have seen "side wheel" grind I don't see how
[Re: hemi-itis]
#2686020
08/09/19 12:58 PM
08/09/19 12:58 PM
Posts: 30,253 Florida STAYcation
dIc dOc Deity !
The village idiot's idiot
Florida STAYcation
ms to have become the norm.If it's going to take a month,say so! I hate when they tell you,,,,,,,,,it will be done on Tuesday,,,,,they just don't say which Tuesday Then you still need to be able to check the work to be certain it is to your spec! Double here ! Some people think towing charges are per mile THEN they get hit for over TWENTY TIMES that !!
[Re: merpar]
#2686298
08/10/19 04:18 PM
08/10/19 04:18 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Walk around Machinary Row at PRI. Look at what machines and tooling costs, on top of a building and everything it takes to keep the door open. Then imagine being between a rock and a hard place - racers who don't understand what's involved and use Chinese made crap for price comparisons, and the need to pay bills, make a profit and have some kind of decent life.
Guys who are still doing it must love it.
[Re: sasquatch]
#2686582
08/11/19 06:40 PM
08/11/19 06:40 PM
Roughbird72
30 years ago there were 3 automotive machine shops within 6-7 miles of my place, now the closest one is 42 miles away.
