69 Charger headlight vacuum hose routing??? #268537
03/27/09 04:16 PM
03/27/09 04:16 PM
Anonymous OP
Anonymous OP
Anyone have a diagram? I'm assuming that the vacuum line "T's" in with the power brake hose and goes right to the canister? or is it supposed to go all the way over the the manifold? There's also a vacuum block up by the brake booster........What runs where? I want it to look correct......
Re: 69 Charger headlight vacuum hose routing??? #268538
03/28/09 06:55 AM
03/28/09 06:55 AM
Anonymous OP
Anonymous OP
It's been awhile scince I looked at mine but I can tell you it uses the vaccum from the brake booster check valve.then goes to the canister under the battery.after that it gets too complicated to remember off the top of my head.I think you can find it in a 68 or 69 shop manual.
Re: 69 Charger headlight vacuum hose routing??? #268539
03/29/09 09:55 AM
03/29/09 09:55 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
not 100% sure if exact but here is a 68 setup.
John Mac
