slop in a BB roller timing chain ?
#2684909
08/06/19 10:05 AM
08/06/19 10:05 AM
Posts: 19,239 north of coder
moparx
how much slop is too much in a roller timing chain ? in my "stuff", i came across a roller [single bolt] timing chain set that looks good. if i bolt it on a block, how much slop [chain stretch] midway between the sprockets, is too much to be a good set ? TIA as always !
Re: slop in a BB roller timing chain ?
[Re: moparx]
#2684964
08/06/19 01:18 PM
08/06/19 01:18 PM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
On one 440 years ago I tried two sets, same Direct Connection part number, just 1 bolt, nothing fancy, sealed in shrink wrap. First set had over 1/4 of slop in the chain, no good. Second set was perfect and I used it. Later I sold the first one with an apology, and the guy said it was perfect on his engine with no slop at all. Was the problem the timing set or the engine? Some would say it doesn't matter as long as a home was found for both parts.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2684984
08/06/19 02:02 PM
08/06/19 02:02 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Align bored blocks will often result in loose chains.
[Re: John_Kunkel]
#2685003
08/06/19 03:04 PM
08/06/19 03:04 PM
ZIPPY
S.E. Michigan
Align bored blocks will often result in loose chains. It was a virgin 1973 production assembly in my case, date coded bearings and all. Not that it matters any, but I sure found it odd at the time.
Rich H.
Esse Quam Videri
[Re: moparx]
#2685045
08/06/19 05:19 PM
08/06/19 05:19 PM
Posts: 4,205 New York
polyspheric
New York
Fatal: install it, and check the slack in several different rotations. If they're different, the chain is toast.
Boffin Emeritus
[Re: Ody1003]
#2686043
08/09/19 01:40 PM
08/09/19 01:40 PM
moparx
well, i installed this gear set on a 383 that was on the rack with the timing cover off. i'm happy to report this set had virtually NO slop on either side. so now, it's bagged up and on the shelf for future use. sorry my old brain keeps forgetting things. thanks all for your helpful responses !
