Re: 69 valiant wiring
[Re: calrobb2000]
#2684967
08/06/19 01:28 PM
08/06/19 01:28 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
To the best of my knowledge, nobodies '69 markers were lit, snafu in the federal regs.
Your two electrical items, I think there's two wires on one end, one on the other.
I have no idea about bulb sockets.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: calrobb2000]
#2685018
08/06/19 03:58 PM
08/06/19 03:58 PM
RapidRobert
there would be 2 blue wires on one end of the ballast, one coming from the ign1 (run) ignition switch terminal via the bulkhead and the other going to the "ign" terminal on the "box" reg. The other end of the ballast would have a brown wire coming from the ignition switch ign2 "crank" terminal via the bulkhead & a blue wire going to the coil positive primary terminal
[Re: 3hundred]
#2685033
08/06/19 04:53 PM
08/06/19 04:53 PM
3hundred
Colleyville
You can download a .pdf of your service manual right here, linky Robert
[Re: calrobb2000]
#2685304
08/07/19 11:40 AM
08/07/19 11:40 AM
RapidRobert
In my 64 dodge shop manual the blue ign1 feed to the ballast is 16 & from that ballast terminal to the reg is 18 & on the other end of the ballast the brown wire feed is 18 & from that ballast terminal to the coil is 14ga. EDIT no sure why that much variation, other than current carrying capacities.
[Re: 3hundred]
#2685356
08/07/19 01:52 PM
08/07/19 01:52 PM
3hundred
Colleyville
Eh, so I was wrong...or not...
Robert
