What kills a big block? #2684501
08/04/19 11:28 PM
08/04/19 11:28 PM
USA
hudsonhornet7x Offline OP
USA
There are lots of theories as to what cracks the main webbing in a typical 383 or 440.
Is there one thing that sticks out as the worst? I would guess detonation but I am usually wrong on these things.
So what is it?
Detonation
Raw horsepower
Compression ratio
Large stroke
I am trying to learn here, and there are way better minds than mine that can give a educated answer. Maybe if Aftermarket blocks become available again this won't be such an issue.
Re: What kills a big block? [Re: hudsonhornet7x] #2684524
08/05/19 01:36 AM
08/05/19 01:36 AM
gregsdart Offline
gregsdart  Offline
Since my tuneup have always been conservative, I believe detonation then rpm combined with non center counter weighted heavy rotating assembly's will top the list, with stroke and compression coming in later, with stroke adding stress when rpm is high.
Re: What kills a big block? [Re: gregsdart] #2684541
08/05/19 06:49 AM
08/05/19 06:49 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
For us, we use stock blocks and make over 700hp....
1. Detonation
2. RPM
My tune ups are spot on, but once in a while, the timing is advanced further than I would like, and that usually shows up in the bearings.
Re: What kills a big block? [Re: Dragula] #2684558
08/05/19 08:18 AM
08/05/19 08:18 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Rotating weight, balance and RPM IMO.
I limit the 505 to 6400 rpm. It makes all the power down low anyway.
'63 Dodge 330
11.19 @ 121 mph
Re: What kills a big block? [Re: GY3] #2684570
08/05/19 09:02 AM
08/05/19 09:02 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
After you get to the 750 HP range it's Russian roulette. I heard about the guy that made 1000 hp with a stock overbored block...................twice shruggy whiney violin
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What kills a big block? [Re: hemi-itis] #2684577
08/05/19 09:28 AM
08/05/19 09:28 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
How many guys are really at the 750 horsepower mark. I'm not talking "happy Dyno" numbers, track numbers. Although I haven't been racing big blocks for the last 10 years in 30 years I hurt ONE block. And that block lasted 275 (8 second) passes before I found a crack. Do you know how long it would take most guys to make 275 passes at the track. A LONG TIME. That block didn't even have aluminum main caps which if I ever built a stock block again would.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What kills a big block? [Re: hudsonhornet7x] #2684578
08/05/19 09:29 AM
08/05/19 09:29 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Reciprocating weight, rotating weight is annoying but relatively harmless.
Boffin Emeritus
Re: What kills a big block? [Re: polyspheric] #2684622
08/05/19 10:51 AM
08/05/19 10:51 AM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
TOO MUCH TIMING! {severe detonation} We were running a crank trigger and the dist. cap clip came off. The dist. cap rotated on it's own! When that happened the timing went to the next terminal in the firing order! BOOM! The crank was in 5 pieces, rods bent, huge window in the block, oil pan, chunks of metal, and a fire from the oil igniting!
Re: What kills a big block? [Re: tjmarcus1] #2684623
08/05/19 10:55 AM
08/05/19 10:55 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It’s easy....... the blocks aren’t strong enough for that power level.
Re: What kills a big block? [Re: fast68plymouth] #2684635
08/05/19 11:22 AM
08/05/19 11:22 AM
iagree
OP, don't start a half serious BB build with either of those blocks if you want it to live around 800 HP at or above 7000 RPM, use a good 400 block with
aluminum main caps and ARP main studs up to 850 HP twocents
Re: What kills a big block? [Re: Cab_Burge] #2684659
08/05/19 12:26 PM
08/05/19 12:26 PM
PA.
"Little"John
"Little"John
PA.
Just to throw something else out there years ago (over 30) we were running low to mid 10’s at 3000-3400 pounds with crack probe forged cranks and the only issue most of us had were the cranks. This was with stock rods, heavy trw and sealed power pistons and junk factory heads. If you were to take a stock .030 block, aftermarket forged stock stroke crank, aluminum main caps, aftermarket H beam rods, and a nice set of TrickFlow, ProMax, Indy, Edelbrock, etc etc heads are you telling me you couldn’t run well and stay together. If not you may need a new engine builder. Everyone has to build a Stroker engines just like they do with small blocks.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What kills a big block? [Re: hudsonhornet7x] #2684672
08/05/19 01:18 PM
08/05/19 01:18 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Its easy to make 1000 hp with a low deck if you aren’t afraid of trying something new.
Slap some turbos, injection, and distributorless ignition on a B engine... you will have all the power you can use with a surplus.
Nitrous, blowers are hard on blocks and cranks.Trying to get over 800 hp on a n/a engine means extreme rpm and ragged edge timing.
You could make 800 hp with a turbo B engine for as long as you could feed it fuel, given a decent tune. Anyone arguing that point hasn’t tried it.
Re: What kills a big block? [Re: TRENDZ] #2684684
08/05/19 01:59 PM
08/05/19 01:59 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Anyone ever look at a small block Ford? Fist time I saw one tore down my thoughts were how in the world does one of those make it around the block without flying apart? But the ford racer guys were turbocharging them and making big hp. If one can do it with a small block ford, a b engine Mopar should not be a problem.
Getting old just means you were smarter than some and luckier than others.
Re: What kills a big block? [Re: dannysbee] #2684687
08/05/19 02:17 PM
08/05/19 02:17 PM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
A small block
Re: What kills a big block? [Re: dannysbee] #2684693
08/05/19 02:46 PM
08/05/19 02:46 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Talking day and night comparing a SBF to a BBM.
The late model 5.0 blocks break quite easily.
72 Plymouth Roadrunner 11.08@123.25
Re: What kills a big block? [Re: pittsburghracer] #2684710
08/05/19 03:25 PM
08/05/19 03:25 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
drinking
Re: What kills a big block? [Re: TRENDZ] #2684734
08/05/19 04:30 PM
08/05/19 04:30 PM
New York
polyspheric Offline
polyspheric  Offline
New York
AFAIK there's a difference in power delivery between a Roots/screw blower (boost at idle if you want) and a ProCharger (boost roughly proportionate to the square of engine speed.
All of them (including turbos) have a smaller spike of maximum cylinder pressure (especially less than nitrous), lasting longer, and occurring later in the crank rotation, which appears to help with breakage.
Boffin Emeritus
Re: What kills a big block? [Re: pittsburghracer] #2684770
08/05/19 06:35 PM
08/05/19 06:35 PM
Dragula Offline
Dragula  Offline
I am....and we have a format we stick to so they live....Been racing stroker big blocks regularly since 2012...We usually pull it apart over the winter for a freshen up, but not always....
You know why we run stock blocks at this level? Cause you can't get any aftermarket ones.....What are us bracket racers to do, buy billet block to run 9's or 10's, switch to the dark side and go get a cheppy? Honestly, this is what it has come to, and I am not happy about it, but we make it work. Yeah we could better heads on and go faster, or shift it 500rpm higher, but how long will a stock block last.......As one person said, that's Russian roulette...
If you don't go crazy with it, and have a good tune up, it should last.....
Re: What kills a big block? [Re: Dragula] #2684773
08/05/19 06:49 PM
08/05/19 06:49 PM
Barboursville, VA
belvedere383 Offline
Barboursville, VA
I think a stock block can live pretty well if the tuneup is right and you have a good machinist.
My current setup is about 3 season in and has had pretty good success.
Its a 66 383 block bored .060 over with ross pistons, manley rods, 440 source 4.25 crank. Indy EZ hand ported heads, indy R3 solid roller camshaft. Cast intake with 1050 dominator.
The car runs 10.0-10.1 on motor at 3610 lbs with a 275 drag radial. I spray it with nitrous on a single Induction solutions plate with a .076 nitrous jet (175hp) and it runs 9.0-9.1 at 149-150.
This combo has been together for about 3 years and seems to be doing just fine to this point, it has to be making somewhere around 1000 hp to the flywheel to run that mph at 3610.
65' Belvedere
496'' Stroker
Indy Heads
Re: What kills a big block? [Re: belvedere383] #2684831
08/05/19 11:48 PM
08/05/19 11:48 PM
When was the last time you had the oil pan off to look at the main webbing?
BTW, that is a stout "383" devil up
