508 hot street engine #2684310
08/04/19 01:08 PM
08/04/19 01:08 PM
AndyF Offline OP
AndyF  Offline OP
We dyno tested a 508 hot street engine the other day. This is a 10:1 pump gas engine with Trick Flow 240 heads, ported Victor intake, modest hyd roller cam and a 850 double pumper. This engine ran great, nice and smooth with no leaks. Made 615 hp and 645 torque so it will be a handful on the street. Going in a 1970 RoadRunner with a four speed.
Re: 508 hot street engine [Re: AndyF] #2684314
08/04/19 01:37 PM
08/04/19 01:37 PM
oregon
greendart408 Offline
oregon
Should be fun, what header size? 1 7/8 to 2?
Re: 508 hot street engine [Re: greendart408] #2684326
08/04/19 02:14 PM
08/04/19 02:14 PM
AndyF Offline OP
AndyF  Offline OP
The headers in the picture are the small dyno headers. They are 1 3/4 stepped to 1 7/8. The owner of the engine was trying to decide between 1 3/4 or 1 7/8 headers so we ran them with the small ones. Still made plenty of power.
Re: 508 hot street engine [Re: AndyF] #2684335
08/04/19 02:42 PM
08/04/19 02:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Cam specs? Torque & HP curve?
Re: 508 hot street engine [Re: topside] #2684343
08/04/19 03:01 PM
08/04/19 03:01 PM
AndyF Offline OP
AndyF  Offline OP
I think the cam was 241/247 with roughly 0.600 lift. It was a custom Comp hyd roller using some of the "fancy" lobes out of the lobe catalog. I didn't take a picture of the dyno sheet. Power peak was in the upper 5000 range, maybe 5600 or 5800.
This 508 is very similar to the 496 that is in my Coronet. Same pistons, cam family, heads, etc. The 496 in my Coronet had peak power of 613 hp at 5800 rpm. So these aren't high rpm race engines, they are performancestreet engines which still manage to squeeze out 600+ hp. Of course you could race the engine but you wouldn't want deep gears.
Re: 508 hot street engine [Re: AndyF] #2684357
08/04/19 04:17 PM
08/04/19 04:17 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
This is what I built!
Love this engine and the torque it has! 3.54 gear and a tight converter suit it well.
'63 Dodge 330
11.19 @ 121 mph
Re: 508 hot street engine [Re: GY3] #2684559
08/05/19 08:21 AM
08/05/19 08:21 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Cool build! Very similar to mine too. Seems hard not to make 600hp w a 500 and tf 240s, but I’m sure it’s possible smile
Curious why the victor intake vs the TF intake? Do you think one is better than the other? Also Andy, do you happen the know the height differences between the two?
2 kids and a dog
Re: 508 hot street engine [Re: TonyS451] #2684626
08/05/19 11:05 AM
08/05/19 11:05 AM
AndyF Offline OP
AndyF  Offline OP
We would have used a Trick Flow intake but they are on back order everywhere at the moment. Evidently Trick Flow is moving their casting vendor or something.
Re: 508 hot street engine [Re: AndyF] #2684683
08/05/19 01:56 PM
08/05/19 01:56 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
thumbsNice!
72 Plymouth Roadrunner 11.08@123.25
Re: 508 hot street engine [Re: Roughbird72] #2684915
08/06/19 10:39 AM
08/06/19 10:39 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
andy f is da man
Re: 508 hot street engine [Re: dart games] #2685239
08/07/19 08:50 AM
08/07/19 08:50 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice. A tried and true combination after all this time.
Rich H.
Esse Quam Videri
Re: 508 hot street engine [Re: ZIPPY] #2685309
08/07/19 11:55 AM
08/07/19 11:55 AM
AndyF Offline OP
AndyF  Offline OP
Yeah, I'm pretty comfortable telling a customer that if they buy these parts they'll have a 600/625 pump gas engine. The Trick Flow 240 heads seem to be the key part but matching them with the correct pistons, cam, and intake is what makes it happen. The good news is that these parts are all fairly easy to source.
Re: 508 hot street engine [Re: AndyF] #2685333
08/07/19 01:04 PM
08/07/19 01:04 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Hey Andy
What rockers did you use and did they need any work to correct the geometry?
Re: 508 hot street engine [Re: radar] #2688556
08/16/19 09:00 PM
08/16/19 09:00 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That cam spec is almost identical to the Trick Flow cam. work
