440 source water pump housing #2684117
08/03/19 05:51 PM
08/03/19 05:51 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
I got one of the aluminum 440 source housings to put on the 440. I will need to replace the heater core in the car later on down the road when i get more time. On the factory housing i had 2 pipe plus in the heater hose outlet holes. On this aluminum housing, one of the holes is bigger and im having a hard time finding the right pipe plug to screw in it. I found one that is 1/2 but the threads dont go all the way up so the head bottoms out on the housing and just starts digging into the aluminum when tightening it..I need the type that gets tight when there is still thread showing. The smaller hole is fine as its the same smaller size as the original housing and the pipe plug works fine in it.
Re: 440 source water pump housing [Re: mopower440] #2684160
08/03/19 08:16 PM
08/03/19 08:16 PM
A regular plumbing 1/2 NPT pipe plug is bottoming out? EDIT IF this is a permanent plugging you might coat the plug with JBweld to get it to seal. Does it appear the hole (which is slightly tapered which pipe threads are) was tapped a bit too deep?) MORE EDIT trying to visualize this, if you shorten the pipe plug would it appear that it would tighten up/seal before the bottom of the plug hit the bottom of the tapped hole?
Re: 440 source water pump housing [Re: mopower440] #2684264
08/04/19 10:33 AM
08/04/19 10:33 AM
moparx Offline
moparx  Offline
can you get a pic to post ? one of the plug, and one of the plug with the "head bottomed" on the housing.
also, what material are the plugs made of ? brass is best [in my opinion], but if using steel or stainless, a good sealer is a must, especially when it comes time to remove them.
beer
Re: 440 source water pump housing [Re: moparx] #2684266
08/04/19 10:41 AM
08/04/19 10:41 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
didnt chrysler run 1/2 and 5/8 hose at one time?------made it really hard to source the correct hose.....
Re: 440 source water pump housing [Re: mopower440] #2684276
08/04/19 11:02 AM
08/04/19 11:02 AM
central il.
second 70 Offline
second 70  Offline
central il.
You need a plug like this one that has an allen head and no shoulder. If you can't find one at hardware store boat dealers sometimes have them.
Re: 440 source water pump housing [Re: savoy64] #2684304
08/04/19 12:56 PM
08/04/19 12:56 PM
A727Tflite Online content
A727Tflite  Online Content
If
My 71 Hemi has these.
Re: 440 source water pump housing [Re: A727Tflite] #2684309
08/04/19 01:05 PM
08/04/19 01:05 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
This what you need?
https://www.manciniracing.com/mahehoni19la.html one 1/2" and one 5/8" heater hose
or
https://www.manciniracing.com/mahehoni19.html both 5/8" heater hoses
Re: 440 source water pump housing [Re: Sniper] #2684376
08/04/19 05:33 PM
08/04/19 05:33 PM
middle Tennessee
middle Tennessee
Got it straightened out..The brass plug i bought did NOT have NPT threads to it..it was threaded with regular threads. I found the correct plug today and it worked fine. Thanks for the help guys!
