1968 Charger....budget bomber #2656573
05/18/19 12:38 PM
05/18/19 12:38 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I traded for this Charger shell last summer. It had been sitting for 20+ years and needs cabin and trunk floor pans but the rockers and frame rails are surprisingly solid. I have several projects that are suffering greatly from scope creep so I HOPE to keep this one as as budget bomber. Something I don't have a ton of money in. The early plan is to ring/gasket a 440 I have sitting in the shop. I also have an 18 spline 4 speed just waiting to be used. I didn't get much with the car, but I plan to use all the cast off/replaced parts from my other 68 Charger resto-mod build. Paint job will probably be a satin or patina job.
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger w/ 6.1L/A518/9"
1968 Charger Bomber 440/4spd
1968 Roadrunner w/ 6.1L/6 speed
2010 B5 Challenger SRT 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2656574
05/18/19 12:40 PM
05/18/19 12:40 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
First thing that bugged me when I got home with it was the bent corner on the driver's side front corner where the inner fender meets the radiator support.
It was still on the trailer when I did this last summer...
View from the top looking down...
I got an old 2x4 and a hammer/dolly and starting tapping away. It's not perfect, but I don't care...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2656654
05/18/19 05:18 PM
05/18/19 05:18 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
saw this on FBBO. gonna be a great build.
1969 Plymouth road runner post 383 4 speed F8
1981 Dodge D150 360 auto
Re: 1968 Charger....budget bomber [Re: basketcase] #2658504
05/23/19 05:15 PM
05/23/19 05:15 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Right before my shoulder surgery in late January, I made sure I got the cabin floor pans cut out. The floor pans had lots of rust/holes but the frame rails and rockers are in good shape...I wish I had a good "before" picture
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2660040
05/28/19 01:48 PM
05/28/19 01:48 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Had 1.5 hours available, so I fired up the air compressor and got to work knocking all the undercoating off of the passenger side inner fender. If you haven't used a needle scaler, you need to try it. A needle scaler gun is super cheap on ebay (like $30-40 shipped) and does a nice job in a reasonable amount of time. The passenger side inner fender took one hour and 15 minutes. I will never use a torch and scraper again...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2660192
05/28/19 10:05 PM
05/28/19 10:05 PM
the great wet north
Superfreak Offline
Superfreak  Offline
the great wet north
Nice job
"Too much to do and not enough time to do it"
Re: 1968 Charger....budget bomber [Re: Superfreak] #2663752
06/08/19 09:00 AM
06/08/19 09:00 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Originally Posted by Superfreak
Nice job
Thank you!
I bought a battery powered Milwaukee Fuel DA sander a while back so I went after the rust on the roof. What a nasty job! THE roof skin has plenty of dings but it's cleaning up pretty nicely! Passenger side....
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2665914
06/14/19 04:27 PM
06/14/19 04:27 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I got the rest of the roof stripped...didn't realize the roof had as many dents as it does!
And I started stripping the cowl...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2668645
06/22/19 09:07 AM
06/22/19 09:07 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
A previous owner hacked up the k member with a torch so its not useable. I removed what was left of the front suspension. Then I fired up the compressor and knocked all the undercoating off the driver's side inner fender, which took about 1.5 hours.
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2671832
06/30/19 08:37 AM
06/30/19 08:37 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
This update won't wound like much but it was a lot of work....I dug out all the sealer in the rain gutters and the forward pillar channels. Getting back under the lip was a major pain but every bit of sealer has been removed. I also removed all the windshield clips and retaining screws from the front windshield channel. I couldn't believe that they all came out! The rear window trim clips and screws were not as cooperative. It helped that the windshield had been out of the car for 20+ years.
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2673434
07/02/19 10:41 PM
07/02/19 10:41 PM
the great wet north
Superfreak Offline
Superfreak  Offline
the great wet north
You are certainly making progress. Keep up the good work. up
Re: 1968 Charger....budget bomber [Re: Superfreak] #2675261
07/07/19 04:09 PM
07/07/19 04:09 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I spent another couple hours with the needle scaler. This time, I did the inner rockers, torsion bar crossmember, cabin floor pan supports, and I started on the rear frame rails and floor pans under the rear seat. I am always amazed how much better they look...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2677274
07/14/19 08:38 AM
07/14/19 08:38 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Before I cut out the trunk floor, both rear frame rail needed patched near the top of the arch. Before aftermarket parts were available for these cars, someone had stripped this car. Apparently they really needed the shock absorber mount/crossmember, but instead of grinding welds to remove it, they used a torch. In the process they cut out sections of the frame rail. I didn't want to replace the whole frame rails so some sections were traced/cut and butt welded in.
Before...
After
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2677449
07/14/19 09:51 PM
07/14/19 09:51 PM
KATY TEXAS
csk Online work
csk  Online Work
KATY TEXAS
Great Job !!!
LINK TO MY STORY http://www.onallcylinders.com/2015/...s-to-build-brilliant-1968-dodge-charger/
512ci 9.7 compression, Stealth heads, 3.54gear A518 OD 4100lb,11.04@123 full street car trim.
Re: 1968 Charger....budget bomber [Re: csk] #2681794
07/27/19 11:26 AM
07/27/19 11:26 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Originally Posted by csk
Great Job !!!
thanks CSK!
I've been trying to find/buy a used rotisserie for the last 3 months and I can't get to one before its sold. I've emailed the seller within 2 hours of listing and it's always already sold. I told a friend and he said "why don't you just use mine?". I didn't even know he had one! So I picked it up and got the Charger mounted. Now I can cut out the trunk floor pan and remove the last of the undercoating from the rear frame rails.
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2684104
08/03/19 04:14 PM
08/03/19 04:14 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Now that the rear frame rails are patched, the next task is trunk floor pan removal. A previous owner used an acetylene torch to cut out pieces of both passenger side wheel houses in order to scavenge patches for another charger. Again, this car was parted out before aftermarket sheetmetal was available...but it's still a bummer considering how solid the driver's side wheel houses are.
I fired up the compressor and got out the sheetmetal trimmer. I use it to trim around both sides of every frame rail edge. This leaves just a thin piece of sheetmetal along the lip of each frame lip. It took me about 3 hours to get the big pieces out and get to this point...
And the pieces/debris that came out...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2688662
08/17/19 08:23 AM
08/17/19 08:23 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I spent about 4 hours grinding spot welds and peeling ip the remaining strips of sheetmetal. It doesn't look too different...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2689082
08/18/19 12:31 PM
08/18/19 12:31 PM
the great wet north
Superfreak Offline
Superfreak  Offline
the great wet north
So I guess this is no longer a budget bomber???
Nice to have friends that will lend you things.
Re: 1968 Charger....budget bomber [Re: Superfreak] #2689575
08/19/19 09:18 PM
08/19/19 09:18 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The scope ALWAYS creeps, but my goal is to keep this as budget oriented as possible. I'm not joking about doing a budget paint job either
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2690603
08/23/19 10:34 AM
08/23/19 10:34 AM
the great wet north
Superfreak Offline
Superfreak  Offline
the great wet north
"Budget paint job".........Look at the paint job Pat did on his charger, I would class that as budget so if you set up like he did then you will have no worries at all. I will be painting my car as well and setting up a make shift booth in my garage. (22'-7"x 25'x 12'-2")
Anyone from Warsaw, IN?
by vinnyd76. 02/20/20 09:17 PM
1988 D50 pickup
by cudaman1969. 02/20/20 08:48 PM
Radiator trans lines fitting?
by cdp. 02/20/20 07:36 PM
Help Identifying Two 340 Blocks
by R/T1968R/T. 02/20/20 07:14 PM
Moparts Recent Posts
1988 D50 pickup
by TRENDZ. 02/20/20 09:27 PM
Looks like I’m done
by David1971. 02/20/20 09:19 PM
Illegal to work on your own car in Sacramento county ?
by Mr. Potatohead. 02/20/20 09:14 PM
