Re: A OR B BODY [Re: fbs63] #2681420
07/25/19 09:31 PM
07/25/19 09:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Couple of things since this is going to see street use with what's likely later-model drivetrain:
Speedo cable from Imperial Services will adapt a '63 speedo input to the later trans output.
IIRC it's a '66 Charger cable?
And the E-brake cable setup may be different: I don't recall on my '63, but my '64 was (both had later rearends).
Use headers for a 440 not a 383; the 383 ones exit into the trans crossmember and require a length of S-bend to clear.
Watch the lower ft corners of the front fenders for tire interference, depending on your setup; I had to trim them back at a 45 angle, about an inch.
A 285/70R15 on 15x8 Ramcharger rim will fit in the rear, usually need to narrow the rear axle a bit, if you want a tall (31") tire for the highway.
Early Bs are 22" radiators so cooling requires a little thought and certainly a fan shroud; clearance is pretty tight.
Re: A OR B BODY [Re: Cab_Burge] #2681461
07/26/19 12:34 AM
07/26/19 12:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted by Cab_Burge
Originally Posted by polyspheric
Remember the '63 8-3/4" has tapered axles and drums, many are seized in place.
iagree
But all things are fixable, some Mouse Milk , heat and the proper puller will remove both sides hammer wrench
The left side, drivers side, is usually stuck worse than the passenger side so do the easy side first and then do the hard one last wrench hammer weld
Good luck up, My 1963 Fury will get a rear end change due to that issue wrench
I put a complete drum to drum 8-3/4 rear from a 65 Plymouth with the floating drums in my 63 and it fit and works good. I actually put it in my 63 before I bought it as my buddy owned the 63 and I always worked on his cars for him as he had me swap the rear in when he owned it before I got it. I also went to a newer (1970) auto 727 trans and got rid of the ball & Trunion and went to standard type U-joints. Rear leaf springs are the same ones as some A-bodies use as the ones in my boys 72 Dart are the same as the ones in my 63 size and lenth wise. But I use 3400 lb rated SS springs as he uses the 3000 lb 002 & 003 SS springs in his Dart. Its just a few things you can change or update to if you like the later drivetrain from the mid 60's to mid 70's. But the changes I made were simple and easy and I am 100% happy with it. Ron
Re: A OR B BODY [Re: 383man] #2681699
07/26/19 10:16 PM
07/26/19 10:16 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Somehow I thought that the push would be for the A body. Is there a 1 7/8 header that gives easy clearance for plug removal for the '63?
Re: A OR B BODY [Re: A/MP] #2681725
07/27/19 12:45 AM
07/27/19 12:45 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run TTI 2" headers with Indy EZ heads that have angled plugs. But they are all easy to change. If the eng is cold I can change all 8 in about 15 minutes. If its hot you have to be careful not to burn your hand or arm of course. Ron
Re: A OR B BODY [Re: topside] #2681775
07/27/19 10:50 AM
07/27/19 10:50 AM
I have a friend who try to buy some adapter cable shifter parts for his 1963 Sport Fury from Imperial Services, nothing but excuses and problems after being billed on his credit card, BUYERS BEWARE of them tsk twocents
Re: A OR B BODY [Re: Cab_Burge] #2681804
07/27/19 01:11 PM
07/27/19 01:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sorry to hear that, Cab - my experience with them was several years ago and went perfectly.
The cable itself did the adapting, so if it's the '66 Charger cable as I seem to recall, that should be available elsewhere.
Re: A OR B BODY [Re: topside] #2681808
07/27/19 01:24 PM
07/27/19 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Unlike a lot of you I tend to go with smaller/lighter cars.. have I owned
A and B-bodies long ago.. but even then I still went with lighter cars
wave
Re: A OR B BODY [Re: pittsburghracer] #2682028
07/28/19 01:21 PM
07/28/19 01:21 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted by pittsburghracer
I want to go as fast as I can go with the smallest amount of cash spent so it’s always been A bodies for me. I like the way they look too so it’s a win win for me
so, a 6.0 LS and a 250 shot?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: A OR B BODY [Re: Spaceman Spiff] #2682029
07/28/19 01:29 PM
07/28/19 01:29 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Lol no I’m a Mopar guy for life sitting here with 2500.00 worth of nitrous stuff and storing it in my spare bedroom
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
