Stock 8-track Radio - Small Internal Amplifier? #2680001
07/22/19 08:45 AM
07/22/19 08:45 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have the 8-track player on the bench out of my warlock and noticed it seems to really distort decent quality speakers when I try to run up the volume. I’m assuming that’s due to a lack of power.
Is there a way to boost the output internally on the radio without too much tear up? Or should I be shopping for a small inline amplifier?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: GoodysGotaCuda] #2680006
07/22/19 08:47 AM
07/22/19 08:47 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not sure how old that 8 track is. decades I assume. Could be a case of dried out caps changing the output. Probably wouldn't hurt to replace them and retest.
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: GoodysGotaCuda] #2680231
07/22/19 08:00 PM
07/22/19 08:00 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Nope U need an external power amplifier, the built-in amplifier within the 8 track player is only 4 watts...
Since the 8 track has no pre-outs U will need a low level adapter to convert the 8 track speaker outputs to line levels..
How much power U need for the external amplifier really depends upon a couple of things; ur average playback level & brand/model of connected speakers.
Just my $0.02... wink
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: Sinitro] #2680269
07/22/19 10:37 PM
07/22/19 10:37 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks! I think I found a small one that will run behind the dash and also offer bluetooth sync up to my phone. That could be entertaining as well.
2020 RAM 1500
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: GoodysGotaCuda] #2680398
07/23/19 10:32 AM
07/23/19 10:32 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm pretty sure the speakers in that truck use a common ground. You'll need to rewire them with a dedicated ground back to the radio. Just doing this while still using the factory radio you'll probably notice an increase in sound quality.
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: MarkZ] #2680926
07/24/19 02:32 PM
07/24/19 02:32 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Good point about the OE factory common speaker ground..
Mike...
Note that if U add an aftermarket amplifier be sure to use ungrounded speakers & wiring. Most likely the aftermarket amplifier has internal bridging circuit as to obtain higher power output.. Whenever an amplifier is bridged all speaker output terminals are above ground, if an output terminal is grounded the amplifier will likely shut down and/or damage may occur..
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: GoodysGotaCuda] #2680941
07/24/19 02:56 PM
07/24/19 02:56 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Stock radios & am or am/fm 8 tracks require 8 ohm speakers & most new high performance speakers are 4 ohm...so you you have to wire them in series if you're using the 4 ohm speakers. That may be the issue. Turnswitch makes & restores factory 8 ohm speaker with better magnets so the sound is much better, so I'd check out their website.
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: Triggerfish] #2681187
07/25/19 10:31 AM
07/25/19 10:31 AM
moparx Offline
moparx  Offline
is "crutchfeild" [sp ?] still in business ? if so, they were the guys to ask for good info on radios, amps, and speaker systems back when.
i didn't google them, so i don't know if they are still around or not.
beer
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: moparx] #2681289
07/25/19 02:50 PM
07/25/19 02:50 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
beer
Yup... Crutchfield is still around...
They are great to do business with and very knowledgeable about present day 12V head units, amplifier, speakers but I would check closely to find out their knowledge about our older 50 year Mopar stuff...
There are big technical & compatibility differences between the old and present day stuff...
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: Sinitro] #2681557
07/26/19 11:22 AM
07/26/19 11:22 AM
moparx Offline
moparx  Offline
good point made about the new stuff sinitro. bow may be tough to find an "oldster" working there these days that remember our old stuff.
beer
Re: Stock 8-track Radio - Small Internal Amplifier? [Re: Triggerfish] #2681634
07/26/19 04:32 PM
07/26/19 04:32 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Originally Posted by Triggerfish
...Turnswitch makes & restores factory 8 ohm speaker with better magnets so the sound is much better, so I'd check out their website.
http://turnswitch.com/speakers.htm
Is interesting.
I might try a few of their speakers in 1960-1980s portable AM/FM/SW radios like the Panasonic RF-2200 or the GE Super Radio II (7-2885F) or original Super Radio 7-2880B
