Using 440 Bellhousing with a Hemi?
#2680630
07/23/19 06:33 PM
07/23/19 06:33 PM
Posts: 4,282 Danville, NH
Mopar_Mike
Danville, NH
I have a 67 Coronet with a 426 hemi and automatic. I want to switch over to a 4-speed. I have a 67 440 bellhousing 2843234 to use. First, will it work with the hemi? second, I know I need an 8-bolt flywheel, but 11" and 172 tooth one? I am wondering about starter issues? I plan to use stock exhaust manifolds and a mini-starter. Third, will other 440 parts ie torque bar, clutch fork, 4-speed driveshaft etc. work. Thanks for your help.
RS23L7 4-Speed
Re: Using 440 Bellhousing with a Hemi?
[Re: ogopogo]
#2680669
07/23/19 08:28 PM
07/23/19 08:28 PM
Mopar_Mike
Danville, NH
Thanks all for your replies and advice.
RS23L7 4-Speed
[Re: Sniper]
#2680708
07/23/19 10:01 PM
07/23/19 10:01 PM
Posts: 643 southern conn
1969gtx
southern conn
If you use 143 flywheel and 67 bell the starter will hit the manifold even mini starter I have seen shimming the manifold with a header flange I'm using 1970 bell 130 flywheel and mini starter still tie fit with manifolds all so use 10.95 clutch 500 hp works well I do have a 67 4 speed hemi bell available
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: dragon slayer]
#2680742
07/24/19 12:05 AM
07/24/19 12:05 AM
Mopar_Mike
Danville, NH
Yeah, I have a 67 18 spline so it will match the 67 bell I have.. hitting the bell with the starter is upsetting though..
RS23L7 4-Speed
[Re: Mopar_Mike]
#2680755
07/24/19 03:20 AM
07/24/19 03:20 AM
Posts: 43,112 Bend,OR USA
Cab_Burge
Yeah, I have a 67 18 spline so it will match the 67 bell I have.. hitting the bell with the starter is upsetting though.. The factory made many 1967 Hem B body 4 peed cars, I'm not sure if all of them or some of them had the 172 flywheel with the direct drive starters and some where built with the 143 tooth flywheel, bell housing and gear drive starters or not I do know you could use a 383-440 130 tooth bell housing with a 10.95 size clutch and a 8 bolt 130 steel or aluminum flywheel as already pointed out to make sure it clears the stock exhaust you might have to have your front bearing retainer turn down to fit into the small front bearing size on the stock bellhousing also, maybe not All the 18 spline 833NP I've owned and work on all had the large 308 front bearings along with the large front bearing retainers, I was using Ansens and Lakewood scatter shields and not stock bell housing to run my old Hemi car in NHRA A/S stock class, that was a non hooking experience for 2.5 yrs
[Re: Mopar_Mike]
#2680824
07/24/19 09:03 AM
07/24/19 09:03 AM
Posts: 766 Ohio
Dan Brewer
Ohio
I have a 67 Coronet with a 426 hemi and automatic. I want to switch over to a 4-speed. I have a 67 440 bellhousing 2843234 to use. First, will it work with the hemi? second, I know I need an 8-bolt flywheel, but 11" and 172 tooth one? I am wondering about starter issues? I plan to use stock exhaust manifolds and a mini-starter. Third, will other 440 parts ie torque bar, clutch fork, 4-speed driveshaft etc. work. Thanks for your help. Best to use 10.5" stuff with Hemi and exhaust manifolds. Clutch size is a non issue.
