70-74 cuda dogleg #2677715
07/15/19 05:24 PM
07/15/19 05:24 PM
n.y
converted Offline OP
n.y
is there anyone making 70-74 cuda dog leg front fender repair sections anymore?
Re: 70-74 cuda dogleg [Re: converted] #2680648
07/23/19 07:19 PM
07/23/19 07:19 PM
n.y
n.y
I guess not.
Re: 70-74 cuda dogleg [Re: converted] #2680748
07/24/19 01:13 AM
07/24/19 01:13 AM
Maryland
MoparMike1974 Offline
Maryland
Re: 70-74 cuda dogleg [Re: MoparMike1974] #2681225
07/25/19 11:46 AM
07/25/19 11:46 AM
n.y
n.y
thanks ,but I am not sure .i saw that but the picture doesn't show the brace/dogleg to be there, you would be able to see it even from the front side (shown) ,the two mounting holes would be seen from the bottom, unless they are just using an old photo of just the patch. I am gonna call them to see.
Re: 70-74 cuda dogleg [Re: converted] #2681580
07/26/19 12:29 PM
07/26/19 12:29 PM
n.y
n.y
I called amd yesterday and spoke to a guy at the "tech" line and was told he thinks it is included but wasn't sure so he went to ask someone else and came back and said it was but didn't know if it was welded to the fender already or not. smh. I did a little more looking around and found it is included but is only about a 5-6 inch section and might not be long enough for what I need. I remember auto body specialties in ct. used to sell them and they were almost full length or at least up to the body line above the wheel opening.. if anyone has one or has a junk unrepairable fender that can cut it out of ,I am interested.
Brake Master Cylinder
by CHRGR69. 08/20/19 10:46 AM
Air mattresses blow away
by bigdad. 08/20/19 09:43 AM
Borgeson st3eering box pump and lines
by RMCHRGR. 08/20/19 09:15 AM
YearOne’s Fresh Crop Of Mopar Emblems
by Rustymuscle. 08/20/19 08:40 AM
Moparts Recent Posts
3500 Dodge Ram Woes
by Sammy. 08/20/19 02:32 PM
Woodward Road Kill Drags
by DUSTER_340. 08/20/19 02:15 PM
Replacing a tired 5.7 with a used low mile 5.7
by MoparJ. 08/20/19 02:11 PM
