blower resister??
#2680738
07/23/19 11:26 PM
07/23/19 11:26 PM
Posts: 954 garnett kansas
rhad
garnett kansas
03 dakota,i replaced the resister last year,now its acting up again,at times i need to bump it to make the fan work,i presume its corroded from heat due to a loose connection?,is this common with this era of dakota??
my ladder of success is missing some rungs
Re: blower resister??
[Re: bobby66]
#2680797
07/24/19 07:22 AM
07/24/19 07:22 AM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
Probably the blower motor. I put one in my Durango earlier this year after smacking the housing for about 8 months. Same deal with my sons '01 Dakota 5-6 years ago. If your Dakota is like my Durango you do not have to pull the dash and case out. Check youtube and google. I pulled my dash just far enough to put a new resistor in which you already did.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2681065
07/24/19 11:07 PM
07/24/19 11:07 PM
rhad
garnett kansas
when i replaced the resister i also replaced the plug with a "high heat" plug,sometimes it comes on by itself sometimes it needs a bump
[Re: rhad]
#2681123
07/25/19 08:27 AM
07/25/19 08:27 AM
I_bleed_MOPAR
Buford, GA
IIRC (I am getting old ), you can get to the blower wires by removing the glove box. The next time it doesn't work (and you have the time), unplug the connector and use either a test light or volt meter across the harness side to see if you have 12v and a ground. You may want to remove the glove box ahead of time just so you don't jar the dash enough to make the motor work when you remove it. If you do have voltage & a ground, then that tells you the motor is dragging. Bad motors are very common in Dakotas/Durangos of this vintage. Tim
