Fired up the new 512 build #2680681
07/23/19 08:52 PM
07/23/19 08:52 PM
It's Complicated
HDNMOPERS Offline OP
It's Complicated
Matt Hensley fired up and broke in the cam today on my low deck 512. Everything went real good. Matt did a awesome job on my build. Can't wait to get in a car. What sucks is the sled im going to put it in. Well it's not ready and won't be for a while. So I may have to buy something to put in. Solid FT Cam break in went great with no problems.Thanks Dwayne Porter for the cam. Engine idles at 50-55 psi hot 75-80 psi when reved. Thats with standard volume melling pump. Used the Fast Fish rear main seal set up. No leaks from the rear seal and no leaks anywhere else. Dominic Thumper 850 carb worked perfect. Thanks Dom. If your gonna run carb call Dominic. Customer service and carb quality is the best. Mike at B3 did me a geometry kit and rocker arm set up was spot on. Larry Smith did my TF 240s and M1 intake and they came out real nice. Met some great people during this build. Ken and Matt at Hensley Performance were great to deal with. Matts attention to detail on the machine work and assembly is first class. Hope to have it on the dyno soon for some numbers.
Re: Fired up the new 512 build [Re: HDNMOPERS] #2680732
07/23/19 10:58 PM
07/23/19 10:58 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Congrats!
I love mine- no replacement for displacement!!
Re: Fired up the new 512 build [Re: HDNMOPERS] #2680807
07/24/19 08:00 AM
07/24/19 08:00 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Cool. Glad to hear all went well with your break in. What is a fast fish rear main seal?
Re: Fired up the new 512 build [Re: mopar dave] #2680891
07/24/19 12:11 PM
07/24/19 12:11 PM
It's Complicated
It's Complicated
Performance-Engine-Seals - Fast Fish Auto Parts.com
Re: Fired up the new 512 build [Re: HDNMOPERS] #2680895
07/24/19 12:34 PM
07/24/19 12:34 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looking forward to some numbers!!
