Power Brake Linkage
#2680502
07/23/19 02:29 PM
07/23/19 02:29 PM
Posts: 2,364 White Plains, NY
VCODE
White Plains, NY
I could use some help. Does anyone know what these power brake linkages are for. I'm pretty sure E body but not 100% sure on the application or years. The top one has CW stamped on it and the rod has a # 2N on it and has larger rod end The bottom one has no letters stamped on it and the rod has a # 1N on it and has a smaller rod end Thanks Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Power Brake Linkage
[Re: fastmark]
#2680805
07/24/19 07:53 AM
07/24/19 07:53 AM
VCODE
White Plains, NY
I agree with dragon. The one with the pin fits the 71 up booster with the smaller hole. The one on top could be a 70 with the bolt and spacer for the larger hole on the 70 booster. It uses a bolt with spacer and not the pin. Thanks for the help. The push rods on both of them has the same size hole. They look different because the casting is bigger from one to the other. Bob
[Re: VCODE]
#2681253
07/25/19 01:12 PM
07/25/19 01:12 PM
Posts: 1,319 VA
dragon slayer
VA
He is not talking about push rod on the linkage, rather how the Booster rod attaches. In 71, they started using pins vice a bolt. The hole size in the 71 up booster rod was smaller and accepted a pin. The 70 and down had a sleeve in a larger hole and accepted bolt and nut. Your bottom pic has a pin in it, so 71 up
[Re: dragon slayer]
#2681271
07/25/19 01:52 PM
07/25/19 01:52 PM
VCODE
White Plains, NY
He is not talking about push rod on the linkage, rather how the Booster rod attaches. In 71, they started using pins vice a bolt. The hole size in the 71 up booster rod was smaller and accepted a pin. The 70 and down had a sleeve in a larger hole and accepted bolt and nut. Your bottom pic has a pin in it, so 71 up Thanks Dragon for clearing that up. Bob
