reverse water flow #2679910
07/21/19 10:39 PM
07/21/19 10:39 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Has anyone played with reverse water flow running it in the manfold frist then in to the block. Helping a friend with a car he just got it has a electric water pump and the supply goes to the intake.and out block called the guy got the car from he say he does not remember why they did it. Thanks
Re: reverse water flow [Re: dragon] #2679922
07/21/19 11:01 PM
07/21/19 11:01 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
I run reverse flow in my big block. Seems to work well...
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: reverse water flow [Re: dragon] #2679938
07/22/19 12:12 AM
07/22/19 12:12 AM
Cooling the heads first is suppose to be worth some power on a drag car up
I need to check my car now to see which way the coolant is flowing, top to bottom or bottom up confused It has a remote mounted electric water pump with four hoses to the block and heads wrench
If it is not top to bottom now it will become that after I'm done thumbs
