Speedo gear 32 vs 31 tooth #2679829
07/21/19 06:35 PM
07/21/19 06:35 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
According to Brewer's, I need a 31 tooth for 3.23s & 28" tire
According to the Interweb, a 32-tooth.
I have a mint 32, a mint 39, and a used 31 with a few teeth knocked off, of course laugh2
What's 1 tooth worth in MPH on this setup?
FWIW, I tend to drive by the tach on the highway, but around town I'd like to know my speed.
Re: Speedo gear 32 vs 31 tooth [Re: topside] #2679831
07/21/19 06:45 PM
07/21/19 06:45 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Check your email & you will be able to compare a 31 & a 32 against your GPS soon. ;-)
Re: Speedo gear 32 vs 31 tooth [Re: Alaskan_TA] #2679833
07/21/19 06:48 PM
07/21/19 06:48 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks, Barry, you Da Man.
GPS ?! laugh2
Re: Speedo gear 32 vs 31 tooth [Re: topside] #2679834
07/21/19 06:50 PM
07/21/19 06:50 PM
I'd want the mint 32 toother in there just cuz how bad the 31 toother is but it'd show the MPH a hair low than actual MPH (might cost you a ticket, might not). The archives has a chart & someone posted a link for a comprehensive chart but I dont have that info. EDIT measure your actual tire dia to get it as dead on as possible (might change what tooth count you need). MORE EDIT the chart someone posted had a MPH/RPM chart that was very helpful & there was something about an Excel worksheet. EVEN MORE EDIT the Excel worksheet in the 2 links are right there on the same page, right in front of me, I missed it.
Re: Speedo gear 32 vs 31 tooth [Re: RapidRobert] #2679853
07/21/19 07:29 PM
07/21/19 07:29 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Yeah, I have the Brewer's chart.
Barry & I are trading my 39 for his spare 31.
Was just curious what the difference would be between 32 & 31...
Re: Speedo gear 32 vs 31 tooth [Re: topside] #2679861
07/21/19 08:00 PM
07/21/19 08:00 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
About 1 mph at 31 - 32 mph
Re: Speedo gear 32 vs 31 tooth [Re: BSB67] #2679901
07/21/19 10:27 PM
07/21/19 10:27 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks.
Re: Speedo gear 32 vs 31 tooth [Re: topside] #2679974
07/22/19 04:57 AM
07/22/19 04:57 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
There is an XLS table on tech section here where makes the exact maths. You could get maybe a 31,45 result. So you decide which one is the best for you based on that ( rounding up or not )
Re: Speedo gear 32 vs 31 tooth [Re: NachoRT74] #2679990
07/22/19 08:03 AM
07/22/19 08:03 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I recently went from a 28 to a 29 and the speedo went from 4mph low to 3mph high. this was with a 2.76 and 26" tires and a 4 speed.
Re: Speedo gear 32 vs 31 tooth [Re: Mr340] #2680033
07/22/19 10:14 AM
07/22/19 10:14 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Maybe go up a tire size or 2 to get it dead nuts.
Kevin
Re: Speedo gear 32 vs 31 tooth [Re: Twostick] #2680035
07/22/19 10:19 AM
07/22/19 10:19 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Kevin
I usually drive 5-7 over so the 3 hi gives me an extra cushion drive
Re: Speedo gear 32 vs 31 tooth [Re: topside] #2680039
07/22/19 10:30 AM
07/22/19 10:30 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
IIRC, when I did the arithmetic years and years ago, each tooth was worth ~ 1.67%. Which meant you should be able to get it within 1% either way +/- if your speedo head is working correctly. FWIW, YMMV, ect. 2¢
Roibert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
