Re: Six Pack outboard vacuum
[Re: lewtot184]
#2772511
05/08/20 03:36 PM
05/08/20 03:36 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
the secondaries should not open/crack open or anything with movement of the center carb throttle shaft. this will really screw up idle/low rpm run. look for a burr or something were the carb linkage screw rides in the throttle arm slot. jimmy jack Studebaker may have put a screw in there at sometime to get the carbs to open sooner and boogered the slot. those connecting rods should never be tight but have a little up and down movement at closed throttle. no movement whastosever on outboards with engine running .. only with Engine OFF
[Re: sogtx]
#2772599
05/08/20 07:47 PM
05/08/20 07:47 PM
Posts: 3,916 usa
lewtot184
usa
the secondaries should not open/crack open or anything with movement of the center carb throttle shaft. this will really screw up idle/low rpm run. look for a burr or something were the carb linkage screw rides in the throttle arm slot. jimmy jack Studebaker may have put a screw in there at sometime to get the carbs to open sooner and boogered the slot. those connecting rods should never be tight but have a little up and down movement at closed throttle. no movement whastosever on outboards with engine running .. only with Engine OFF no movement with the engine running is correct.
[Re: A39Coronet]
#2772623
05/08/20 09:23 PM
05/08/20 09:23 PM
sogtx
upstate western ny
What rear gear? Being that it's a 4 speed, I'd imagine even with 3.55s it would be pretty short and lots of tire spin. I'm guessing it's load related
My 6 pack blows through first so quickly I doubt the vacuum is held long enough to open the secondaries before I shift to 2nd. Maybeee spot on , thats why im wonderin if i should adjust the rev limiter to 7k But not sure — 354’s now Itll do wheelies with 4:10’s .. lol
[Re: sogtx]
#2772654
05/08/20 11:15 PM
05/08/20 11:15 PM
Posts: 604 TN
1DGEMAN
TN
Some interesting reading here
Real Men shift for themselves
[Re: A727Tflite]
#2772669
05/09/20 12:21 AM
05/09/20 12:21 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
If you suck on the pod vacuum hose then close the hose off with your tongue while holding the kill bleed closed with your finger the throttle blade should stay open. If it does and doesn’t bleed down you don’t have a leak.
As a quick test, place a strip of duct tape into the throttle bore and cover the kill bleed hole on both front and rear carbs.
Take it for a ride. This
[Re: BSB67]
#2772728
05/09/20 07:57 AM
05/09/20 07:57 AM
sogtx
upstate western ny
Take it for a ride. This lol .. next post , stay tuned .. how do I get the duct tape out from between the planes of intake .. I think it would be cool to try. Ive never done that . , it sounds like I can for a day temporarily be John Force after a duct tape mod. . This all helps to more understand how it all works in unison .. Tom , or others .. do you swap / have different kill bleed carbs for polyglas racing vs regular fat tire racing ? or rely on springs only ..
[Re: sogtx]
#2772819
05/09/20 11:29 AM
05/09/20 11:29 AM
Posts: 3,069 Michigan
A727Tflite
In response to getting the tape out between the planes of the manifold - make that piece of tape long enough to cover the kill bleed then come up over the air horn of the carb and past the air cleaner gasket flange. The air cleaner lid will hold the tape from being sucked in the engine.
My car in Stock Elimator back in the late 70’s ran 11.50’s in NHRA trim.
9” tire, auto, factory lift hydraulic cam, blueprinted short block and heads using STOCK internals, factory pan, factory intake - race weight was 3725 lbs. on the starting line. I can’t drive it on the street without any problems today.
Using all the stuff available now, cams, more ratio, ported heads with bigger valves, etc. you should have no problem running tens.
Piece of cake.
