1968 Plymouth Tach wiring #2679506
07/20/19 05:56 PM
07/20/19 05:56 PM
Omaha
road Offline OP
road  Offline OP
Omaha
Have my tach installed on my 68 GTX based on FCM.
Need to get it hooked up to a switched source from the ignition because it is bleeding battery.
It is a factory tach and it works just fine except for its thirst.
You can reference an option to tie into from the wiring diagrams.
Re: 1968 Plymouth Tach wiring [Re: road] #2679523
07/20/19 07:24 PM
07/20/19 07:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Take your test light and hit the fuse block to see what is hot with the key on and goes dead with the key off. That is the source you want.
