5.7 temp gauge and EFI temp sensor
#2678864
07/18/19 08:57 PM
07/18/19 08:57 PM
Posts: 1,545 Michigan
Kiddart
I think I have a small problem, I have my temp gauge electric sensor that I had on my old manifold from my 415, next to that in the other hole I had the EFI temp sensor. On the 5.7 I only have one npt hole. I need the temp sensor for the efi and I still want my gage to work.
any ideas?
Thank you Kiddart
Re: 5.7 temp gauge and EFI temp sensor
[Re: Kiddart]
#2678989
07/19/19 09:29 AM
07/19/19 09:29 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
On my daughters D100 we used the 04-08 car timing cover, the back of the block(the passages that go no where) had been tapped and the Heater hoses connected to them , That's where we put her mechanical gauge , installed at-fitting .
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2678990
07/19/19 09:33 AM
07/19/19 09:33 AM
Kiddart
I think I am going to drill and tap a new hole opposite side of the factory location on the front top of block. its the triangle area just behind the front cover. on the drivers side there is a boss that I have the efi sensor in so I am going to drill and pipe tap just opposite of that. and hope for the best. should work just fine. cross my fingers. I will let you all know how it works out.
Thank you Kiddart
[Re: Kiddart]
#2679209
07/19/19 08:03 PM
07/19/19 08:03 PM
Kiddart
All done, i figured i would screw this up somehow. But not this time
Thank you Kiddart
[Re: Kiddart]
#2679309
07/20/19 05:06 AM
07/20/19 05:06 AM
Ray408G3Hemi
Springtown Pa
Looks good to me.
